Go to Post Once you get to college, remember that FRC is not your life anymore (or at least it doesn't have to be). Don't be afraid to try new things, and branch away from the things you swear by in high school - buildmaster5000 [more]
Unread 17-03-2011, 20:00
siggy2xc siggy2xc is offline
AKA: Tyler Siegrist
FRC #1756 (Argos)
siggy2xc is an unknown quantity at this point
Team 1736 Autoflex 1.1
Our autoflex program will allow you to record and playback what you do. To use our autoflex code ("Autoflex Team1736 v1.1.zip") all you need to do is change the directory ("C:\Users\Siggy2xc\Desktop\lvSaves\") in the long flat sequence at the bottom of "Autoflex.vi" to whatever directory you would like to save your recording to ("c:\ni-rt\" if you are running from the cRIO) then run "Tester.vi"
To add or remove inputs right-click the "Input" local variable's border in "Read Inputs.vi" and choose open type def. create indicators for each control then ctrl+drag your indicators from "Read Inputs.vi" into the type def. box, delete the indicators, and save. Then wire those controls to the bundle function.
If there are any questions I would be glad to help, the only thing I ask for is to report any bugs you find and suggest any improvements you would like to see. Enjoy!
Unread 19-03-2011, 10:58
AKA: Tyler Siegrist
FRC #1756 (Argos)
Re: Team 1736 Autoflex 1.1
Wasn't loading file correctly but appeared to because of the data that was left over in the joystick event array from recording. It is now fixed.
Unread 14-03-2013, 20:02
nathav63 nathav63 is offline
FRC #0107
nathav63 is an unknown quantity at this point
Siggy2xc, I was wondering if there was a README file or something of the like. My main problem is that I don't know what to do with the Tester vi as the instruction to 'run' it is quite vague.
Thanks!
