Go to Post If you guys ever need anything, just let us know. Just remember you have the FIRST family behind you.<3 - hayleybayley217 [more]
Unread 14-03-2013, 22:32
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Joysticks
Originally Posted by cvessalico View Post
We are also experiencing our joysticks randomly drop out. This was happening a lot last year during our regional. We switched to a different joystick this year, an xbox usb controller without led lights. It seemed to be working fine all weekend in NYC then in the semifinals it happened again (of course perfect timing It was strange because this time only one joystick dropped out (the xbox one) the other joystick, a logitech gamepad, remained functional. Anyone know why this might be happening? And what can we do to avoid this at our next regional.
Press F1 to rescan joysticks.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Joysticks
Isn't F1 also the ENABLE hotkey?
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 15-03-2013, 13:48
Re: Joysticks
Yes, but it only enables when you are not connected to FMS. Therefore, on the field, you can check your joysticks before the match, and press F1 if they are not connected. You can also press F1 during a match if you discover it during the match (or a joystick gets accidentally disconnected). There are more details in the FMS whitepaper. http://www.usfirst.org/sites/default...Paper_RevA.pdf
Unread 15-03-2013, 21:03
AKA: Matt B
FRC #1771 (1771)
Re: Joysticks
Ah, great information, thanks.
I just know the two hotkeys we use...
Enable (F1) and Stop (Enter).
Spacebar reserved for fires.
1771- Mentor (2015)
Unread 14-03-2013, 23:25
cvessalico cvessalico is offline
FRC #0884
cvessalico is an unknown quantity at this point
Re: Joysticks
We'll try that but.... Has anyone else experienced this and if so how can we fix it so the joysticks never drop out!!
Unread 15-03-2013, 09:31
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Re: Joysticks
Are the joysticks plugged into a USB hub or directly into the USB ports on the driver station? We had a similar issue twice in the past and both times it was related to the USB hub that we were using. Once it was that the devices were not getting sufficient power from the single USB port to support them both. The second time it was the USB hub that had its own signal continuity issues; these problems disappeared when that hub was replaced. In both cases the signals to the joysticks were dropping out sometimes momentarily and sometimes persistently. We have since eliminated the hub from our driver station (since we have only 2 USB devices and no longer need the external e-stop button) and have had no issues like that since.
