Go to Post You must have a base on which to stand. Knowledge is the base that wisdom stands on. - Steve W [more]
Unread 14-03-2013, 22:07
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
Measuring RPM for a Free-Spinning CIM
Hey
How can i measure the RPM of our shooter CIM if the CIM is not connected to a gearbox.
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 14-03-2013, 22:16
Re: Measuring RPM for a Free-Spinning CIM
Originally Posted by 2185Bilal View Post
Hey
Many teams make their own home-brew one-count-per-rev optical or magnetic sensor. A sensor like that is excellent for shooter wheel speeds, if decoded properly.
Optical: Paint half the wheel white and the other half black, and sense it with a photosensor.
Magnetic: put a pair of magnets on the wheel, 180 degrees apart, and sense it with a latching Hall sensor (US1881 works well)
There are many other configurations.
Unread 14-03-2013, 22:19
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Our team used the light sensors from 2011 and programmed a tachometer to output to the DS. By putting a piece of electrical tape on a wheel, we were able to use this as a "tick" mark in programming. Review team 358's example under Tachometer for sample code. If you are interested in this, message me and I'll help you get it set up.
Unread 14-03-2013, 22:48
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
We used a photo sensor and a piece of retro reflective tape that is pretty darn accurate, we have it so that we don't shoot in autonomous until it speeds up, then when it senses a sudden drop it waits until it speeds up again, then coasts down when it senses the next Frisbee. It also lets us detect jams, and stop the motor to prevent fried motors.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 14-03-2013, 23:00
2185Bilal's Avatar
AKA: Bilal Majeed
where can i get a photo sensor
RAMAZOIDZ
Unread 14-03-2013, 23:02
read post #3
