Go to Post Is your team sponsored by Rube Goldberg? - bdaroz [more]
Unread 24-01-2003, 19:39
hi_im_sean hi_im_sean is offline
hi_im_sean is an unknown quantity at this point
gearbox efficiency
i read somewhere that the gearboxes for the drill motors(i mean the helical ones that go on the drive shaft) only have 47% efficiency. now i dont know if that is true but if it is will that slow down the robot to matter.
[EDIT]** enough to matter[/EDIT]
Unread 26-01-2003, 21:29
Dick Linn's Avatar
no team (Synergy)
Re: gearbox efficiency
I would expect the efficiency of a right-angle helical gear arrangement to be at least as good or better than a worm gear. While worm gears can be as bad as 35% efficiency (with a high reduction ratio, like 70:1), I understand that they are typically 65-80. I would anticipate these gears being somewhere around 80-85% efficient. A good parallel shaft helical arrangement can be as good as 98% efficient.
I would be much more concerned with the mounting of the motor, the dimensions of the spacer tubing that holds the two gears in alignment inside the gearbox and lubrication. Even the best gearbox can arrangement can be made inefficient!
Want to see what "gear-heads" talk about? Check out http://www.qtcgears.com/Ask/index.asp If you want some general info about gearing, check out this primer from Georgia Tech: http://www.srl.gatech.edu/education/...og/gearbas.htm
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
Drill gearbox clutch Joe P Technical Discussion 3 12-03-2003 13:22
Connecticut teams, gearbox needed GaelHawks230 General Forum 0 08-03-2003 13:41
gearbox for atwood motors DaveG702 Motors 3 17-12-2002 10:30
Specs for drill motor gearbox? archiver 2000 4 23-06-2002 22:36
