Go to Post FIRST: there is no second. - BandChick [more]
  #31   Spotlight this post!
Unread 15-03-2013, 11:58
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: How is 54" size limit being inspected?
Originally Posted by Jaxom View Post
How do you handle situations when the 54" cylinder isn't perpendicular to the floor?
It has to be perpendicular to the floor when you're not in contact with the pyramid, so problem solved. It's also a lot harder to have a robot that doesn't fit in a cylinder when climbing, since there are infinite orientations for the cylinder to be and it only needs to fit in one to be legal.
  #32   Spotlight this post!
Unread 15-03-2013, 23:30
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Originally Posted by Tristan Lall View Post
Unless they're not in a plane perpendicular to the axis of the cylinder....
Ok, two points projected onto the ground plane then.
  #33   Spotlight this post!
Unread 16-03-2013, 00:12
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
This doesn't solve the problem if the part of the robot that goes outside of a perpendicular cylinder only extends when the bot touches the pyramid. You still have to find that one cylinder that fits. What I'm asking is how a circle on the floor helps with this? Do you have the kids hold the robot at various angles until you either find one or give up?
I inspected a bot at GKC where we used carpenter's squares and long pieces of square aluminium stock as a guide for my tape measure. We were able to find a cylinder that fit. If the team ever extends their climbing appendage while not touching the pyramid they'll violate the rule; no way around it. This was time-consuming and tedious; I would like to think there's a better way.
Mentor http://www.teamtitanium.org/
