Go to Post Wait - a single message outlining the vast majority of where to find controls stuff? Goodness. What will they think of next. - Tom Line [more]
Unread 14-03-2013, 15:50
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Reggie335 is an unknown quantity at this point
Joysticks
Hey is there anyway to see if there is something wrong with my joysticks.
Unread 14-03-2013, 15:56
Re: Joysticks
More info needed to provide a useful answer.
Unread 14-03-2013, 16:14
AKA: Reginald
Re: Joysticks
my program is working perfectly but when i am in my FRC Drivers Station and i go Diagnostics i see that my Joysticks aren't blinking when i move them; they only blink when i press the joystick buttons that's it
Unread 14-03-2013, 16:26
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
Re: Joysticks
That is the expected behavior.
Unread 14-03-2013, 17:01
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
Re: Joysticks
In Windows, you can go to "Set Up USB Game Controllers" to see if they are working.
Unread 14-03-2013, 22:21
cvessalico cvessalico is offline
FRC #0884
cvessalico is an unknown quantity at this point
Re: Joysticks
We are also experiencing our joysticks randomly drop out. This was happening a lot last year during our regional. We switched to a different joystick this year, an xbox usb controller without led lights. It seemed to be working fine all weekend in NYC then in the semifinals it happened again (of course perfect timing It was strange because this time only one joystick dropped out (the xbox one) the other joystick, a logitech gamepad, remained functional. Anyone know why this might be happening? And what can we do to avoid this at our next regional.
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Joysticks
As stated above, that is normal.
Have you actually tried testing them with the robot enabled?
My guess is you'll be happily surprised with the results.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 14-03-2013, 22:32
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Joysticks
Press F1 to rescan joysticks.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
AKA: Matt B
FRC #1771 (1771)
Re: Joysticks
Isn't F1 also the ENABLE hotkey?
1771- Mentor (2015)
Unread 14-03-2013, 23:25
FRC #0884
Re: Joysticks
We'll try that but.... Has anyone else experienced this and if so how can we fix it so the joysticks never drop out!!
Unread 15-03-2013, 09:31
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Re: Joysticks
Are the joysticks plugged into a USB hub or directly into the USB ports on the driver station? We had a similar issue twice in the past and both times it was related to the USB hub that we were using. Once it was that the devices were not getting sufficient power from the single USB port to support them both. The second time it was the USB hub that had its own signal continuity issues; these problems disappeared when that hub was replaced. In both cases the signals to the joysticks were dropping out sometimes momentarily and sometimes persistently. We have since eliminated the hub from our driver station (since we have only 2 USB devices and no longer need the external e-stop button) and have had no issues like that since.
Unread 15-03-2013, 13:20
AKA: Reginald
Re: Joysticks
can anyone help
Unread 15-03-2013, 13:22
Custom User Title
AKA: Cal
Re: Joysticks
can anyone help
With...
Unread 15-03-2013, 13:31
Re: Joysticks
Some laptops disable or limit the power draw from USB ports on battery power, or when battery is below a certain level. You may be able to disable this behavior. I've also seen weird results when using some USB hubs.
Make sure you always check the joysticks before the beginning of the match.
Unread 15-03-2013, 13:41
AKA: Reginald
Re: Joysticks
thanks i really needed to know that
