Go to Post Good thing you skipped this year. You don't need exhaustion to sleep through Recycle Rush. - Gregor [more]
Unread 15-03-2013, 17:16
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
Re: CAN and Jaguars, any limits?
We had a similar issue around 7 Jaguars on our practice robot before we realized we had a "bad" termination resistor. We swapped it out, after much other troubleshooting, and it resolved the issue. I can't explain the failure, but I'm sure changing the termination resistor is what fixed it. Typically, no termination results in only 1 Jaguar showing up on the CAN.
I put "bad" in quotes above because we were able to use the "bad" termination resistor on a different CAN bus with 2 Jaguars without issue.
You might give it a try; it's easy enough.
