Go to Post It is possible to live without the Big sponsors, it just takes a lot of fund raising and hard work. - Raumiester2010 [more]
Unread 15-03-2013, 13:10
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
Teach programmers
I am going to be head programmer next year and part of my job will be to teach new members interested in programming. I was wondering if people had any ideas on how to effectively teach programming, since I am not a great teacher (took 20 minutes to teach my brother how to play checkers ). Any thoughts would be appreciated. Many thanks.
Unread 15-03-2013, 14:13
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
Re: Teach programmers
Prepare lots of hands on exercises. Start with normal desktop programming for simplicity, but make sure that you quickly move to actual robot code. You'll need a lot of time if you actually want to make these people good.
Most of the specifics depend on the language you use.
FRC 612 '12
USNA '16
Unread 15-03-2013, 18:24
AKA: Ethan
We use labview to program, but many of the members come in knowing C/C++ or Java.
Unread 15-03-2013, 21:22
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
I generally start them on the FRCMastery videos, then have them do a traffic light state machine outside the robot code, then move a robot motor with a joystick or button in teleop starting from the base robot code, then work up from there.
Unread 15-03-2013, 21:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
If your incoming members are strong, really strong, in C++ or Java, you might consider switching to that for your programming language. It's a lot easier to learn to program if you're only learning the logic of programming a robot and not trying to learn all the syntax and quirks of a new language as well. Then too, labview programming is rather different than C++ or Java. As an experience C++ programmer, it took me quite a while to really get my head around labview and how it works when I first encountered it.
Unread 15-03-2013, 21:52
pasco27 pasco27 is offline
Programming Captain-Team RUSH
FRC #0027
pasco27 is on a distinguished road
Team RUSH has developed labview programming documents and we distribute them to rookie members as well as rookie teams and they said it really helped
http://archive.teamrush27.net/resources/rookies.html
they are the programming guides under labview tutorials
Good luck
Matt Pasco
Unread 15-03-2013, 22:04
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
swwrobotics is an unknown quantity at this point
Good luck
Matt Pasco
Could not open the links. They led to a page not found error...
Unread 16-03-2013, 00:50
sg999 sg999 is offline
Programming Lead, Co-Captain 2013
AKA: Bella
FRC #0999 (Mecharams)
sg999 is a splendid one to beholdsg999 is a splendid one to beholdsg999 is a splendid one to beholdsg999 is a splendid one to beholdsg999 is a splendid one to beholdsg999 is a splendid one to behold
This year, we had 2 new programmers who knew nothing about programming. They ended up writing most of the code. The only thing that they didn't write was the PID loop code, as no one on our team knew how to do that before this season.
First, we had them come in for a couple hour long sessions after school in which we (the other veteran programmer and I) explained variables, subVI's, control structures (case structure, while loop, for loop), and other basic programming stuff in both technical terms and more relatable terms (We ended up with a huge extended analogy comparing a room full of magic boxes to the code). We then had them come in a longer after school session in which they wrote tank drive code during which we explained what the subVI's are supposed to do (why do I need to initalize a motor, etc). Next, our programming mentor took a day to make a water tank state machine with us. We then sent them home to read ni's tutorials on whatever they didn't understand. To get the new programmers programming, we had a policy that a new programmer must always be sitting in front of the programming laptop, with their screen projected on the wall. We started off by talking them through everything (Click here- that VI you just selected allows us to set motor output, etc), and eventually moved up to them programming almost independently. Because we had a bench to test on, all of our teleop code was done, tested, and theoretically working by the end of week 4. The only things we've done since there were changed negative signs, ports, and added a PID loop.
tl;dr: Use hands-on activities.
There is always time-whether or not you use it productively is up to you.
2012-WIWI 6th seed (Thanks for being awesome alliance partners, 1991 and 178)
2014-present College student at Caltech (math/CS)
Unread 16-03-2013, 15:02
AKA: Ethan
Thanks guys. I have been working on "tutorial code" that contains basic functions such as loops, variables, etc. Hopefully these will help me teach people without overwhelming them.
Unread 16-03-2013, 16:07
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
this is something we're looking at using to learn Java. It's "virtual" battle bots using Java or .NET It allows for programmers to just focus on code without the hardware problems. Haven't tried it yet though...
http://robocode.sourceforge.net/
I'll also ditto the above that say if you know C++/Java, why not code your bot with it?
Unread 17-03-2013, 10:22
jcbc's Avatar
jcbc jcbc is offline
AKA: Julie
jcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the rough
I second ("third"?) the importance of teaching state machines once basic programming and control structures are understood. State machines are not language dependent and they are useful for robot programming. Part of our fall programming training is having the programmers (new and experienced) write code that implements a given state machine.
Unread 17-03-2013, 14:27
This page is probably the one Matt should have given:
http://www.teamrush27.net/rookie-resources
Unread 11-04-2013, 09:38
AKA: Ethan
Thanks for your input. Me and the other veteran programmers have made an executive decision to switch to C++ and are already happy with it.
Unread 06-05-2013, 12:25
mlbernardoni mlbernardoni is offline
FRC #2704
mlbernardoni is on a distinguished road
For C++, Team 2704 has developed a training program for FRC that uses NXT robots. The training is directly applicable to FRC robots, but each student can program their own little robot. So if you access to NXT(s), check out www.FirstPlusPlus.com
Unread 06-05-2013, 13:52
lcoreyl's Avatar
AKA: Milner
Wow, this is really great work. thanks for sharing!
