Go to Post It doesn't seem hard, but it is. You can do it with enough time, dedication, and skill, but that doesn't stop it from being hard. - lemiant [more]
Unread 17-03-2013, 14:58
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
ohrly? is an unknown quantity at this point
Things to keep router away from
I've heard that the strength of the radio signal is affected by where it is placed on the robot (for instance, that it should not be next to motors).
Does anyone know which items which interfere with the radio and to what degree?
Unread 17-03-2013, 15:37
Re: Things to keep router away from
Keep them away from large chunks of metal. This year, that might include pyramids.
Two years ago I saw a robot with communication issues that went away after the router was relocated away from Jaguar speed controllers. I was told about a second robot that was said to have had the same problem and same fix, but I didn't see it myself.
Unread 17-03-2013, 15:42
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Putting it near motors and other electronics is the biggest no-no, but non-energized metal can cause significant issues. Get it as up high as you can. We mounted ours to Lexan (which isn't supposed to interfere), but there are other ways to do it.
Unread 17-03-2013, 16:56
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
What you want to avoid is anything that generates electromagnetic noise and anything that blocks signals. Basically, that works out to staying away from the motors and the motor controllers (noise) and not putting the radio inside anything that might be described as a metal box (RF shielding). Higher is better, more exposed is better (within reason). Lexan shielding isn't a problem.
Putting the radio on a metal belly-pan with all the motor controllers, directly between two drive motors, and under a shooter motor and sheet metal shooter deck is the worst possible position I can think of offhand. If this sounds like what you've done, you should really think about making a change.
Unread 18-03-2013, 11:04
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
This explains a lot.
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 18-03-2013, 11:50
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
I hadn't given our router placement much thought until looking at this thread. I find your exact description of our router placement to be a little eerie (Edit: although no problems yet)
One more thing to go on the todo list...
Unread 18-03-2013, 17:50
ohrly?'s Avatar
Griffin Alum
AKA: Colin Poler
Thanks! I think we're safe this year, but we're brainstorming ways to make our electronics board better next year. Do you think putting it above the battery is fine?
Unread 22-03-2013, 13:37
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Treat the radio like an antenna. Higher is better, away from large metal surfaces is better, away from large current draws (motors, compressor) is better.
