Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 17-03-2013, 17:22
dheerm's Avatar
dheerm dheerm is offline
Drive Team and Head Programmer
AKA: Dheer Mirchandani
FRC #0224 (The Tribe)
dheerm will become famous soon enough
Re: Shooter consistency
our team was having trouble with encoders as well. Yes different battery voltages do matter when sending a value to a Victor because the value sent to the victor is the equivalent of a percentage of your current voltage. So to try to get a better measurement, I tried a last minute fix.
Wheel Motor Voltage = Value sent to Victor * Battery Voltage.
Therefore, Value Sent to Victor(Or other speed controller) = (End Voltage / Battery Voltage).
All you have to tune is the End Voltage that you want your wheel to have. Batter Voltage can be calculated (in Java) by instantiating a DriverStation object and using the getVoltage() method.
Same method should be in other API's.
It didn't give us 100% consistency but it did significantly improve it. There are of course other variables.
"All you need is duct tape and a dream"
Team 224:
District Champions @TCNJ w/ Team 56 and Team 293
8th alliance captain at MAR championships w/ (take a guess) , Team 56 and Team 293.
www.team224.com
