Go to Post Don't test your autonomous on the comp field. There's a practice field for a reason. - DampRobot [more]
Unread 17-03-2013, 12:23
shindigo shindigo is offline
AKA: Mike Parker
FRC #0102
shindigo is an unknown quantity at this point
Reassigning button.whenPressed during teleop
Hi,
I think this is a straight-up technical question. How can we reassign the command that is assigned to button.whenPressed during teleop?
We tried something like :
CommandBase.oi.myPublicButton.whenPressed(new myOtherCommand())
within a command, but this does not seem to work. The button still executes the original command we had assigned to it.
Tia - mp
Unread 17-03-2013, 20:30
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Reassigning button.whenPressed during teleop
I don't think it's possible. Button.whenPressed() calls Trigger.whenActive(), which adds a ButtonScheduler to the Scheduler's internal list of buttons. I don't think there's a way to remove it. I believe there is an alternative, though.
Custom buttons are pretty easy to make, they just need a get() method. So, if you want an easy way to disable a certain button binding, have a variable:
Button doubleBoundButton; // this is the button you want to trigger differently at different times
boolean initialBindingEnabled = true;
Button initialBinding = new Button() {
           public boolean get() {
               return initialBindingEnabled && doubleBoundButton.get();
       secondaryBinding = new Button() {
               return !initialBindingEnabled && doubleBoundButton.get();
You can then bind different things to each:
initialBinding.whenPressed(new DoSomething());
secondaryBinding.whenPressed(new DoSomethingElse());
Then, to toggle which is enabled:
initialBindingEnabled = !initialBindingEnabled;
I code stuff.
Unread 17-03-2013, 23:08
AKA: Mike Parker
FRC #0102
Wow -that is some pretty snappy code! I have never seen the override of a get in a new before, but I'm a relative novice at java. Can any public method be overridden for an instance of a class in Java? I will give it a try tomorrow night.
Btw, do you have a link to the source of the wpilib? There are times when I would like to understand more about what is going on behind the scenes.
Thanks -
Mike Parker - programming mentor, team 102
Unread 18-03-2013, 18:45
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Thanks -
https://github.com/1684chimeras/2013...cedButton.java
lil something i made, allows you to assign different commands to different modes than set the mode of the button (e.g. set A to lock for drive, B for climb in climbing than set the mode of all the buttons to 2 when u want to climb)
Button source code is in C:\Users\yourname\sunspotfrcsdk\lib\wpilibj.src.zi p
to your override question.... Yeah you can override any public method. You can also use super.(method) to refer to the method that you were overriding
Unread 18-03-2013, 19:07
Ginto8's Avatar
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
In Java, you can override any non-final method, and anonymous classes (new ClassName() { /* stuff */ }) let you make individual variables with specific versions of methods, instead of having to make a new class every time you want to make a tiny change.
In the sunspotfrcsdk folder (which should be in your user directory), in its lib directory, there are wpilibj.src.zip and wpilibj.project.zip. The src one just has the source files, and the project one is a full netbeans project. The more complicated aspects of command-based programming are in edu.wpi.first.wpilibj.command and edu.wpi.first.wpilibj.buttons.
I code stuff.
Unread 22-03-2013, 07:16
AKA: Mike Parker
FRC #0102
Great! Thanks for the pointer!
Unread 22-03-2013, 12:59
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
There are no pointers in Java.
Unread 22-03-2013, 21:09
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Yes there is. Not the type ur thinking of
Unread 22-03-2013, 22:54
Ginto8's Avatar
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Everything except primitives is a pointer in Java. You might prefer to call them references, but references are themselves just less flexible (and less dangerous) pointers.
I code stuff.
