Go to Post WATER GAME! Always a water game... - kendra21093 [more]
Unread 26-01-2003, 22:55
Thunder360 Thunder360 is offline
#0940 (Digital Demolition)
Thunder360 is on a distinguished road
Hmmm
You know tank treads arent a bad Idea because you will have a O degree turning radius. but I really wouldnt only use 2 Cim's I would use 2 Cim's and 2 drills at the same speed. Err I dunno if that would work, but I was always a huge fan of 2 wheel rear drive with 2 Cim's with 2 Pneumatic shifted gears.
But I bet most rookie teams will try to go direct drive with the drills. I always use a multi speed tranny with any motor!
P.S. Anyone have a good design for a 3 speed thats Pneumaticly shifted, I can only manage a 2 speed in the given space. And Im also having a down shifting problem its a lil rough, but thats expected from helical gears right?
"Who needs Battle Bots, Ive got US FIRST!!!"
Unread 26-01-2003, 23:36
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Originally posted by rbayer
First, the CIMs are 5500rpm, not 4200. http://www2.usfirst.org/2003comp/Specs/Chiaphua.pdf.
According to that paper, the freespeed is 5342rpm, but it's 4356rpm under normal load. 4200rpm is a conservative estimate.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 27-01-2003, 00:44
KennethToronto's Avatar
KennethToronto KennethToronto is offline
#0820 (Delta Tech)
KennethToronto is an unknown quantity at this point
Send a message via ICQ to KennethToronto
No....do NOT use a 3:1 reduction and call it a day
We're using similar wheels and I'm reducing the CIMs by ~20:1
North Toronto CI
Delta Tech Team 820 Robotics
Unread 27-01-2003, 02:28
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
Yay, we finished mounting the motors to the 5/8" coupling gear shaft and found that we could easily hold the shaft in place and trip the fuse, so we def need more torque. 1:20 sound excesive, I'll look into a 1:8 ~ 1:12 range.
Thanks
Unread 27-01-2003, 12:30
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Thanks
Rather than guess, use this White Paper as a starting point.
Then, take the information you learn about speed and apply it to torque and see where you end up.
Math is better than guessing. (Only marginally.)
--Madison--
...down at the Ozdust!
Unread 05-02-2003, 10:44
gc02 gc02 is offline
gc02 is on a distinguished road
Originally posted by wysiswyg
Actually you have them reversed. A three to one gear ratio would triple the speed of the robot and a one to three gear ratio would increase the torque of the robot by a factor of three. I believe your confusing the speed ratio and the torque ratio which simply enough are inverses of each other.
I think you have it reversed, according to dictionary.com here is the defenition of "gear ratio":
The ratio of the speed of rotation of the powered gear of a gear train to that of the final or driven gear.
Greg
Enigma Industries
Unread 08-02-2003, 10:26
Lord,
I have to go with everyone else on this. The gear ratio sounds too high especially with the 9
' wheels. The chalupa motors are strong but the gear ratio will allow you to go fast only if you can get the robot moving. That is a big "if" since the gear ratio will provide so little torque. 8-12 feet per second is a good guide.
As to the electrical draw, the 40 amp breakers are the dominant factor and I would predict some heavy action on their part with this design. Turning will be your greatest draw.
Unread 09-02-2003, 20:48
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Like I've stated before, Our Team has (somehow) managed to get 15 feet per second with a 10:1 ratio using the 2 Chiphua Motors, and we still have loads of torque. We aren't a speed based robot...
Anyway, OUr drive is really nice and (if only) if chiefdelphi had a section dedicated to video clips, I'd show you our drive in action!
I might be able to get a file server and post a link in a while...
Anyway, we Haven't had any issues with it, and it works great!
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Chassis Material/Construction sanddrag Technical Discussion 51 05-12-2003 12:59
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
