Go to Post My favorite question of all time asked by "outsiders": How much does/did that thing cost? How can you put a price on the hard-work and dedication it took to build these machines? - KyleGilbert45 [more]
Unread 18-03-2013, 12:37
Akash Shah's Avatar
Akash Shah Akash Shah is offline
FRC #4954 (4-H Palindrome Robotics Club)
Akash Shah is an unknown quantity at this point
Question Hopper Design
After last weeks TCNJ FRC District Competition. a few other team member and I had a though about changing our hopper design and adding a new human player feeder. and we came up with a design of a square hopper because it would have less areas of contact with a frisbee than a circle but still does its job of holding the frisbees in. It also solves many other problems we have been having with a circle hopper. How do you guys think about this?
FIRST Robotics Competition Team 4954
Co-Lead Mentor/Alumni
Drexel University Class of 2019
Unread 18-03-2013, 13:53
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Hopper Design
Just go to Home Depot/Lowe's and buy a bucket like everyone else is. It's a solid solution that is cheap and easy. Also if you cut it wrong it just costs $5 to get a new one.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 18-03-2013, 13:55
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Hopper Design
What problems have you had with the circular hopper?
Unread 18-03-2013, 14:04
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Re: Hopper Design
We switched from a square hopper to a circular hopper after running into a lot of issues with frisbees not stacking particularly well in the square hopper and jamming the feeder. Square wasn't the way to go for us. I think the more sides you have keeping it centered the better, and a circle has infinite sides.
Drawbacks: the circular hopper is tempermental to any pinching, so you have to be careful to keep it round with any attachments or fastening.
Unread 18-03-2013, 14:15
Pendulum^-1's Avatar
Pendulum^-1 Pendulum^-1 is offline
AKA: Jim Grove
FRC #1915 (Firebird Robotics)
Pendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nice
Re: Hopper Design
Get a five gallon bucket from Lowe's/Home Depot. (I recommend getting several...so you don't hesitate to experiment/screw up...they cost us less than $3 each.) The buckets are great because they taper only slightly, almost imperceptably from the top to the bottom. Put a disc into the top....and it stops about 6 inches from the top. Draw a circle around the bucket where the disc stopped. Slice the bucket at this line or just above it, to establish the bottom edge of the hopper. (We used a Dremel with a metal disc cutter or sharp box cutter to cut the bucket.)
The slight taper in the bucket is nearly the perfect shape to keep the discs stacked, yet not nested so much that they do not separate or jam, and not so tight that they jam in the cylinder as they drop.
From there, experiment with an exit slot in the bottom (needs to be 1.4 inches high), a means to transition from the hopper to the chamber/shooter barrel (we use a pneumatic piston, without any clevis attached), and a means to feed it. For feeding, we cut about 225 degrees around the uphill and top edge of the bucket, cutting down about 1" from the top. With the sloped cover to the shooter, we have a good backstop for discs to hit, and drop into the hopper.
Dozens of examples are shown in the reveal videos. Your own geometry will vary, depending on you shooter configuration and space available on the robot.
Jim Grove, Mentor
firebirds1915.blogspot.com
(2007-2017) 1915, McKinley Tech HS, Washington, DC
(2009) 2932, Mid-Pac Institute, Honolulu, HI (Rookie Season)
(2011) 2425, Hillsborough HS, Tampa, FL
(2013-2015) 4464, College Park, MD, 2013 Rookie All Star Winner and 2014 Regional Champions, Washington, DC
FIRST is not rocket science. But it is like drinking from a fire hose.
Unread 18-03-2013, 14:51
Akash Shah's Avatar
We have been using a circular hopper made out of a 6 gallon bucket we found. We went through our district competition with one. And it had issues of the frisbee getting stuck and not falling in straight. So I was wondering if a square would be better.
Unread 18-03-2013, 14:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Hopper Design
Use a 5 gallon bucket from home depot / ace.
We prototyped square and it was a mess. Two days later we were back at a bucket. Rember that you can't use the whole bucket, only the top 6 or 7 inches is wide enough to pass a frisbee without binding.
Unread 18-03-2013, 15:05
Racer26 Racer26 is offline
Re: Hopper Design
4343 and 1114 went the 'dont stack the frisbees' route, which seems to be less jam-prone, provided you only index a single frisbee at a time into the pre-launch position of the shooter.
4343's design made human loading quick, and prevented the frisbees from jamming up their hopper by falling in sideways as is possible on many robots I've seen.
Unread 18-03-2013, 15:21
Akash Shah's Avatar
Alright. thanks for the advice guys
Unread 18-03-2013, 17:34
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Hopper Design
They only fell out the top
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 18-03-2013, 18:05
Re: Hopper Design
Well, yeah. The indexer motor needed to be about 3" further down the hopper, and that problem would have been entirely alleviated.
Unread 19-03-2013, 12:28
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Re: Hopper Design
we have a custom made sort of square shaped hopper, with "stairs" that we built out of polycarb. here's a video where u can see how it works and stacks Frisbees... altho i'm not sure i'm supposed to be sharing it
http://www.youtube.com/watch?feature...&v=f_v3UbFI_6U
Unread 19-03-2013, 14:59
Herbblood's Avatar
Herbblood Herbblood is offline
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Herbblood is an unknown quantity at this point
Re: Hopper Design
We had a square hopper, but in order for things to work perfectly, it became very complicated. It also became very finicky, working one day and not the next. We're currently switching to a round hopper.
Good luck with what your trying!
Off to WPI!
Go OxBE4
Unread 19-03-2013, 15:51
rebagley rebagley is offline
FRC #3847
rebagley is an unknown quantity at this point
Re: Hopper Design
We've been using a square hopper and it's been working pretty well for us--we tried the bucket method briefly, but decided it wasn't really worth it for what we were trying to do. However, we do collect and shoot from the bottom (we built it for floor collection, but after Lone Star we decided that it might be better to human feed through the bottom slot, and it's working quite well for us) and it's powered, which helps make collection quick and reliable.
Unread 19-03-2013, 16:22
Akash Shah's Avatar
What are your dimensions for ur hopper?
