Go to Post How well does peanut butter transmit heat? - Lil' Lavery [more]
  #31   Spotlight this post!
Unread 18-03-2013, 14:31
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Pyramid variation
Originally Posted by mwmac View Post
However, I also believe that the simplest solution to pyramid variability would be an amendment to the playfield setup procedure for FTA's requiring a height check and adjustment of the base plate positioning. This change could help relieve teams of the need to perform ad hoc modifications to their robots that may otherwise prove to be completely unnecessary at future events. Just my .02
This is an interesting idea. Has anyone been able to get data about how much the pyramids change over the course of match play? They flex a lot and I've noticed the pipes routinely coming apart; I had to push some back together after every match I reffed. Does anyone know just pushing things back together enough to keep everything in spec once it's readjusted? Or would more work be required? Regardless, even doing it once would be better than the current way now.
I know we cleared all 8 quite well in a practice round, and were surprised the next day that we hit one, but I'm not sure what did it.
  #32   Spotlight this post!
Unread 18-03-2013, 17:38
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
One of the things I didn't realize until week two of competitions this year (the first week I had to assemble the field) is that the bar height spec is to the base carpet. There is a layer of masonite and a second layer of carpet on top of the masonite around the pyramid. That has thickness that makes the measured bar to carpet distance seem short.
Wetzel
Viva Olancho!
  #33   Spotlight this post!
Unread 18-03-2013, 21:34
jbsmithtx's Avatar
jbsmithtx jbsmithtx is offline
FIRST Fanatic
AKA: Josh Smith
FRC #4206 (RoboVikes)
jbsmithtx is a jewel in the roughjbsmithtx is a jewel in the roughjbsmithtx is a jewel in the rough
Originally Posted by jspatz1 View Post
Identical to this at Hub City.
If I remember right, the pyramids at Hub City were different heights. I believe the red tower was higher than the blue (I know from personal experience because I rammed the red tower with about an 1/8" of the top of our robot, and then cleared it (accidentally; robot got stuck) on the taller blue one. If I remember right, the red pyramid was the one that was 28 5/8" with the blue one being about 28 7/8" to the bottom, but don't hold me to that.
