Go to Post (Funding will be plentiful...) Where is this magical land? We can move our team there! - Tungrus [more]
Unread 18-03-2013, 21:46
AsianRookie AsianRookie is offline
AKA: Steven/Tim
FRC #0321 (Robolancers)
AsianRookie is an unknown quantity at this point
Problem with driving
Hey guys, we recently had a problem with driving on the field and only on the field. We tethered it and ran everything, it was fine driving. However on the field, the robot would just not move well. It jerks and does not respond to the controller. We also know it is not a bandwidth issue. Does anyone know a possible fix?
should I set setSafteyEnabled to false?
Unread 18-03-2013, 21:49
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Problem with driving
You should make sure that your radio is mounted away from metal parts of the robot and motors. Those can lead to bad reception and/or interference and cause you problems like you are currently experiencing.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 18-03-2013, 21:55
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Does this happen shortly after the transition from autonomous to teleop? Look at the driver station logs; what does the CPU usage jump to? It sounds like the same problem that jumps up on teams time to time - an infinite loop that your robot get stuck in that spikes CPU usage up to 100%. You won't be able to replicate it in the pits because you're running tethered, and it's pretty hard to lose packets that way.
Academic Student (Forever)
Unread 18-03-2013, 21:59
AKA: Steven/Tim
The radio is mounted away from motors. I am running at around 43% cpu.
Unread 18-03-2013, 22:33
Andrew Lobos Andrew Lobos is offline
FRC #0225 (TechFire)
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
When I was helping you in your pit with your compressor code, I noticed the debug output from the cRIO said Robot drive not updated often enough. Since it did that right when the cRIO was enabled, and then stopped, I assumed that you had some initialization stuff happening that took time to complete. I didn't notice any output after that.
Is this happening while you are driving?
In your testing, are you driving on carpet? I noticed you were running 1 CIM through a CIMple box with 6in wheels. How far is your voltage dropping when you drive? If you use the Driver station log viewer app, you can see the cRIO log (including voltage) from your matches.
If you still believe it is a code problem, make absolutely sure your RobotDrive or motor controller objects are having their drive/set methods called every loop.
- Andrew
Unread 18-03-2013, 22:42
AKA: Steven/Tim
- Andrew
The voltage drops to about 9volts.
The robotdrive is in the execute method.
We didnt drive on the carpet, only on the practice field.
This happens to driving. I re-coded the drive a bit, to compensate a dual joystick controller for one of our drivers. I am hoping that is going to fix it as well as setting the setSafetyEnabled to false.
Unread 18-03-2013, 22:47
CalTran's Avatar
MST Rolla Senior
9 volts is dangerously low...we change our our batteries when we see it drop down to 11.2...
Unread 18-03-2013, 22:51
AKA: Steven/Tim
9 volts when "driving", 12.5 when not.
Unread 18-03-2013, 22:52
Gregor's Avatar
Happy Birthday! Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
9 volts is still very low when driving.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Did you notice the jerking when driving straight or only when turning? I'm not a mechanical person, but it really looks like your gearboxes contribute to your issues.
Feel free to correct me if I'm wrong on this:
- 6 inch wheels
- 4.67:1 reduction in CIMple gearboxes
- 1 CIM per gearbox
- 1:1 chain linkage to wheels
For this configuration, JVN design calculator says you have a max speed of 24.11 ft/sec and a maximum pushing force of 60.26lbs.
Also remember that the WPILib Scheduler calls your execute() methods on one thread - if one starts blocking it will affect other commands.
Unread 18-03-2013, 22:53
AKA: Steven/Tim
from last year's logs, that seemed to be like a normal.
Unread 18-03-2013, 22:55
For reference, our bot this year has 6 CIMs on the drive through 6:1 VexPro gearboxes. We rarely dipped below 11 ( 10 minimum ) volts on a fresh battery driving on carpet.
Jay1986's Avatar
Jay1986 Jay1986 is offline
Programmer and Driver
AKA: Jay Urban
FRC #1986 (Team Titanium)
Jay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the rough
We only use fresh 12.8ish Volt batteries once a match, we start to experience drive problems when the battery gets to 10.5ish volts standby. There could be many things making you experience the driving problems. By the way, what programming language do you guys use? Also, I know you said it wasn't bandwidth but, your problem sounds just like bandwidth.
2013 Oklahoma Regional (Regional Winner, Gracious Professionalism, [and judges voted me star of the day])
2013 KC Regional (Regional Winner, Woodie Flowers, Industrial Design)
2013 Hub City Regional (Regional Winner, Entrepreneurship, Quality, Dean's List)
Unread 18-03-2013, 22:58
AKA: Steven/Tim
hmm, i wonder why it dips down so much. We use java, command base. I know its not a bandwidth problem because the trip time was not high at all.
Unread 18-03-2013, 22:59
CalTran's Avatar
MST Rolla Senior
- 6 inch wheels
- 1 CIM per gearbox
It's dipping so low because you're simply stalling the motors when you even try to move.
