Go to Post good to have you on board the Circus Train Jane - Wayne C. [more]
Unread 18-03-2013, 21:43
eruiz22 eruiz22 is offline
FRC #4210
eruiz22 is on a distinguished road
Pyramid Contact Question
The rules say that during autonomous mode a robot has to be touching the pyramid. Can we place our robot in such a way that the robot touches the second beam of the pyramid but is not hanging onto it?
Thanks
Unread 18-03-2013, 21:46
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Re: Pyramid Contact Question
Thanks
I think you answered your own question. Is the second beam part of the pyramid?
Mentor http://www.teamtitanium.org/
Unread 18-03-2013, 22:11
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Your robot has to be within the 54" cylinder at the beginning of the match, it can expand once the match begins, but when you set it up it has to be within the size limit. Correct me if I'm wrong, but I believe the second bar is just outside the 54" cylinder.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 18-03-2013, 22:19
jbsmithtx's Avatar
jbsmithtx jbsmithtx is offline
FIRST Fanatic
AKA: Josh Smith
FRC #4206 (RoboVikes)
jbsmithtx is a jewel in the roughjbsmithtx is a jewel in the roughjbsmithtx is a jewel in the rough
I think he is discussing going upwards. In this case, I do not think touching the second beam would be acceptable, simply because you would be "seen" as attempting a climb and jumping levels. Even if you simultaneously were touching bar one, I think then that is touching three different levels which is also prohibited... I think you must therefore either touch a diagonal piece or the 1st beam if I understand everything right?
Unread 18-03-2013, 22:20
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Your robot must be in a legal playing configuration at all times. If you're touching the pyramid, the pyramid configuration rules apply and you're legal as long as you can fit a 54" diameter, 84" tall cylinder around your robot in SOME orientation. It's really rather difficult to be outside that cylinder.
To the OP,
It's legal, but what is your purpose in doing this? I feel I should point out that if you're touching the second level and the floor, you have an invalid climb and will need to stop touching the second level before you can score climb points.
Unread 18-03-2013, 22:22
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
There is no penalty for contacting non adjacent levels of the pyramid, so "seeming to climb" isn't an issue. If you attempt to climb straight for level 2, there is no penalty, but no points either.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 18-03-2013, 22:26
There's nothing in the pre-match rules about not appearing to climb. the rules are the you must be in starting configuration, fully supported by the floor, and touching the pyramid. The second level is still the pyramid, ergo it's legal. It probably isn't smart since, as you point out, you're touching the floor and the second level, and thus have invalidated your climb points. But it's certainly legal.
Unread 18-03-2013, 22:29
robowrestler's Avatar
robowrestler robowrestler is offline
AKA: Collin
FRC #3015 (ranger robotics)
robowrestler is an unknown quantity at this point
your lights on your driver station would also be yellow meaning its a bad climb but as long as you back away after auton you should be fine
2016 Pittsburg Regional Chairmans Award Winners
2016 Pittsburg Regional Finalists with 1023 and 4050
2015 Newton Division Finalists with 195,1756,4522
2015 Finger Lakes Regional Winners with 4039and 378
2015 Finger Lakes Regional Engineering Inspirational Award Winners
2014 Finger Lakes Regional Finalists with 340 and 3044
2013 VA Regional Finalists with 2363 and 2053
2012 Finger Lakes Regional Finalists with 340, 4124 and 3044
2012 Buckeye Regional Winners with 340 and 1507
"Kickin Bot Since 2009"
Unread 18-03-2013, 22:32
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Further, starting this way doesn't automatically invalidate your later climb. You just need return to touching level 0 in a valid climb orientation (including bit touching level 2) before conducting your actual climb. Put it this way, it's perfectly legal to say, shoot by pulling yourself directly up to the 3rd rung (why you'd want to notwithstanding)--you just can't get climb points by staying there.
If you can touch the second rung starting inside your frame perimeter, under 84" tall (if contacting your autozone), without being in any way supported by the pyramid, and abiding by all other rules (remember G07, maybe?), you shouldn't have a problem. I've seen a few robots this could makes sense for, like say those arm shooters who might want to start inside on occasion.
Unread 19-03-2013, 18:03
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Definition of starting configuration:
STARTING CONFIGURATION:
"The physical configuration and orientation of the ROBOT when the MATCH is started.
snip
In the STARTING CONFIGURATION, no part of the ROBOT may extend outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc
snip"
You can touch any part of the pyramid you can legally reach, but you need to be within the frame perimeter of your bot.
