Go to Post Let's just say that I am old enough to... - dlavery [more]
Unread 18-03-2013, 23:35
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: CNC Plasma Cutting Chassis
Originally Posted by mman1506 View Post
Is it possible to make rivet holes on the plasma cutter?
Yes, but depending on the quality and calibration of your machine, you may have to have them be cut small and then drilled to size.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 19-03-2013, 00:01
REVving up for a new season
FRC #2848 (All-sparks)
The answer is yes, but there are some limitations which as others have pointed out have to do with the cut quality you can get from your machine. As a general example: Would I cut pockets and location holes with a plasma, yes. Would I build an integrated gearbox in a chassis, no.
The limitations I think it is important to be aware of are bending. It is extremely hard to bend accurate parts with a cheap break, and this can be as much as of a limitation as the cutting machine. The method I prefer when using a plasma is to cut location based features on the flat plates and add simple flanges for strength, which geometrically don't need to be as accurate.
A cnc Plasma cutter is an extremely valuable tool for a team to have as it can significantly reduce time and increase accuracy, you just need to learn the limitations of which ever machine you get, and make sure to experiment before the build season to learn what those limitations are.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 19-03-2013, 00:40
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Thanks for all the help,
I'm hoping to design and build a chassis in the off season that we can modify for build season so I can learn how to use it. We do have some heavy duty brakes from the 50's but I'm not sure how accurate they are.
Are table is a plasma cam with advanced height control and are cutter is a miller 375.
Unread 19-03-2013, 11:03
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
In 2012 Team1325 got our chassis conveyor and shooter cut with a plasma cutter and then gave it to a sponsor to bend. It worked out very well all in all. The cuts were not clean and took a lot of niners...i mean deburring. Also small holes (0.25 inch)did not work well so we ended up just drilling most of them in.
I forgot to mention...it was a sheetmetal chassis 0.09 5052 aluminum.
CAD of the chassis:
http://www.chiefdelphi.com/media/img...38d05805_l.jpg
Feroz Balsara
Team 1325 Inverse Paradox
FIRST Volunteer, College Mentor, Lead Design and Strategy Mentor!
2013 GTR West Semi-Finalists with 1241 and 2013!
2013 GTR East Champions with 1114 and 2056!
2011 GTR West Finalists with 610 and 1334!
Team1325.com
Unread 19-03-2013, 22:25
DonRotolo's Avatar
Back to humble
FRC #0832
Small features like rivet holes are best drilled - although you can 'mark' their location with the plasma torch. Better are larger features, but the edge condition may not be as smooth as you prefer. It isn't like milled, laser or waterjet surface finish.
With aluminum, beware the effects of heat on the material - aluminum expands as you torch it, and so when it cools everything gets a little smaller (and closer together...).
Unread 20-03-2013, 11:10
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Don hit the nail on the head what we do to put holes in parts. We undersize and finish the holes on a drill press.
For bearing holes we precision ground a step drill to finsh the holes for a perfect press fit.
The thermal expansion is manageable by controlling feeds and knowing how much you can cut before pausing the cutter and letting things cool along with the order of the cuts. We do primary holes first (location critical items like bearings or interfaces) and then leave lightening holes and frame cutting for later with cooling down time allowed between the patterns.
Also the best way to clean the edges and remove the slag is a scotchbrite pad on a die-grinder. Deburring tools are a bad idea to try on the slag they skip off easily and don't clean it well.
Thank-you 294 & 67
www.bobcatrobotics.org
Last edited by Peter Matteson : 20-03-2013 at 11:11. Reason: i need to proof read better....
Unread 20-03-2013, 18:10
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
You can also strip it of its heat treat in the area surrounding the hole.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
