Go to Post The most important things for a team to take to any competition are a sense of humor, a big bottle of Advil, and a camera! - Rick TYler [more]
Unread 17-03-2013, 21:34
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
CNC Plasma Cutting Chassis
Our team has a CNC plasma cutter (PlasmaCam) laying around that I want to put to good use. I'm hoping to plasma cut our robot's chassis next year but I'm not sure it has the accuracy to do it. We also have a CNC Mill but it has a smaller working area.
Has any team successfully plasma cut there robot's chassis and/or parts? Any tips?
Thanks,
Unread 17-03-2013, 22:42
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: CNC Plasma Cutting Chassis
We've cut parts in steel using a plasma cutter. We haven't had any problems with the parts - they were cut very accurately. Occasionally we have to drill a small hole out though because the plasma cutter doesn't recognize it enough/give it enough power. I think that is due to our configuration of the device, some setting we need to change somewhere.
On a side note has anyone ever plasma-cut aluminum? We were planning on doing it sometime this week and could use some pointers.
Here is our frisbee-launcher being cut this year http://www.youtube.com/watch?v=RUpf_stUnaw
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 17-03-2013, 22:50
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Yep, we do a lot of stuff out of aluminum.
Not sure what system you have, and there are a lot of variables at play here, but what we've found is that it's better to run slower feed rates than suggested by the manufacturer, as this leads to less beveled edges. This will cause more dross buildup, so you will have to do some sanding/filing afterward.
Feel free to ask if you have any questions.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 18-03-2013, 08:10
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Our 2012 robot was all plasma cut. There are a few things you need to learn out but it works well.
This is the best pic on CD of our 2012 robot:
http://www.chiefdelphi.com/media/photos/37782
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 18-03-2013, 12:15
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
While not quite the same thing, our chassis was laser cut from plywood. The machine works in the same way with a rail for each axis and is very accurate. As long as your plasma cutter is well calibrated, you shouldn't have any problems.
Unread 18-03-2013, 21:01
mman1506's Avatar
no team (WARP7)
Is it possible to make rivet holes on the plasma cutter?
Unread 18-03-2013, 21:04
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Not exactly the same thing... Glad to know someone else is doing the plywood chassis. You should put up some pictures of it
Mentor 2415
Unread 18-03-2013, 23:35
rahilm's Avatar
AKA: Rahil Mehta
Yes, but depending on the quality and calibration of your machine, you may have to have them be cut small and then drilled to size.
Unread 19-03-2013, 00:01
REVving up for a new season
FRC #2848 (All-sparks)
The answer is yes, but there are some limitations which as others have pointed out have to do with the cut quality you can get from your machine. As a general example: Would I cut pockets and location holes with a plasma, yes. Would I build an integrated gearbox in a chassis, no.
The limitations I think it is important to be aware of are bending. It is extremely hard to bend accurate parts with a cheap break, and this can be as much as of a limitation as the cutting machine. The method I prefer when using a plasma is to cut location based features on the flat plates and add simple flanges for strength, which geometrically don't need to be as accurate.
A cnc Plasma cutter is an extremely valuable tool for a team to have as it can significantly reduce time and increase accuracy, you just need to learn the limitations of which ever machine you get, and make sure to experiment before the build season to learn what those limitations are.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 19-03-2013, 00:40
mman1506's Avatar
no team (WARP7)
Thanks for all the help,
I'm hoping to design and build a chassis in the off season that we can modify for build season so I can learn how to use it. We do have some heavy duty brakes from the 50's but I'm not sure how accurate they are.
Are table is a plasma cam with advanced height control and are cutter is a miller 375.
Unread 19-03-2013, 11:03
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
In 2012 Team1325 got our chassis conveyor and shooter cut with a plasma cutter and then gave it to a sponsor to bend. It worked out very well all in all. The cuts were not clean and took a lot of niners...i mean deburring. Also small holes (0.25 inch)did not work well so we ended up just drilling most of them in.
I forgot to mention...it was a sheetmetal chassis 0.09 5052 aluminum.
CAD of the chassis:
http://www.chiefdelphi.com/media/img...38d05805_l.jpg
Feroz Balsara
Team 1325 Inverse Paradox
FIRST Volunteer, College Mentor, Lead Design and Strategy Mentor!
2013 GTR West Semi-Finalists with 1241 and 2013!
2013 GTR East Champions with 1114 and 2056!
2011 GTR West Finalists with 610 and 1334!
Team1325.com
Unread 19-03-2013, 22:25
DonRotolo's Avatar
Back to humble
FRC #0832
Small features like rivet holes are best drilled - although you can 'mark' their location with the plasma torch. Better are larger features, but the edge condition may not be as smooth as you prefer. It isn't like milled, laser or waterjet surface finish.
With aluminum, beware the effects of heat on the material - aluminum expands as you torch it, and so when it cools everything gets a little smaller (and closer together...).
Unread 20-03-2013, 11:10
Don hit the nail on the head what we do to put holes in parts. We undersize and finish the holes on a drill press.
For bearing holes we precision ground a step drill to finsh the holes for a perfect press fit.
The thermal expansion is manageable by controlling feeds and knowing how much you can cut before pausing the cutter and letting things cool along with the order of the cuts. We do primary holes first (location critical items like bearings or interfaces) and then leave lightening holes and frame cutting for later with cooling down time allowed between the patterns.
Also the best way to clean the edges and remove the slag is a scotchbrite pad on a die-grinder. Deburring tools are a bad idea to try on the slag they skip off easily and don't clean it well.
Thank-you 294 & 67
Last edited by Peter Matteson : 20-03-2013 at 11:11. Reason: i need to proof read better....
Unread 20-03-2013, 17:38
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Robo Hamsters is on a distinguished road
Our "Trap Door" on our shooter was plasma cut aluminum.
http://youtu.be/dcJLn9UXuoI?t=1m24s
We have a mentor that has a plasma cutter and he made several of our parts on it. Ifyou hae any specific questions I could forward it on to him.
Unread 20-03-2013, 18:10
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
You can also strip it of its heat treat in the area surrounding the hole.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
