Go to Post It'd be nice if, one day, people just concentrated on how to inspire your own team and your own community. Let others decide on how to inspire theirs. - George1902 [more]
Unread 19-03-2013, 08:20
Rodney's Avatar
Rodney Rodney is offline
Programmer...ish...
FRC #1243 (Swartz Creek Dragons)
Rodney is an unknown quantity at this point
Help with shooter angle closed loop
My team has been having a little difficulty with the accuracy of our shooter angle.
Our shooter angle has a bit of a knock back when we fire a disk, and just the 'P' loop was not enough to move the shooter that couple degrees back to position. I tried getting a 'PI' loop and now the slightest of bump will cause our angle to go unstable.
float bias = 1.1932;
float brads = 0;
float cop2axis = (copjoy.GetRawAxis(2));  //this is the co-pilot joystick that is controlling the angle.
if (ds->GetDigitalIn(7) == true) {
	if (cop2axis > 0.15){
		potsetpoint = potsetpoint + .0001;
		last = true;
		randomtimer.Start();
	if (cop2axis < -0.15){
		potsetpoint = potsetpoint - .0001;
		last = true;
	if (randomtimer.Get() >= 0.1){
		last = false;
		randomtimer.Stop();
	float potdiff = (abs(potsetpoint - anglepot.GetVoltage()));
	brads = (anglepot.GetVoltage()*50);
	if (potdiff <=.02000){
	bias = ((bias * cos(brads))/128);
	potset = potset + bias;
	}else {
	if (potsetpoint < anglepot.GetVoltage()){
		potset = ((potsetpoint-anglepot.GetVoltage())*3.5);
	if (potsetpoint > anglepot.GetVoltage()){
	potset = ((potsetpoint-anglepot.GetVoltage())*4);
		if (potset>=1){
			potset= 1;
		if (potset<=-1){
			potset= -1;
		angle.Set(potset*-1);
also, my code was adapted from the attached pdf file.
If I'm missing any info, please post below.
Rodney Dennings
Team #1243 Programmer
Unread 19-03-2013, 09:53
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: Help with shooter angle closed loop
I would just try using PD
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
