Go to Post Quit hitting me with lexan, I'm NOT a pinata. - hcps-ruwedt [more]
Unread 19-03-2013, 09:15
Jaysonscott Jaysonscott is offline
FRC #1846
Jaysonscott is an unknown quantity at this point
Solenoid and compressor help
Sorry i dont mean to post another thread but our team leaves tomorrow for our regional competition and i cannot get my compressor or solenoids to work! it is probably because of my code but im not sure! can anyone help me through this step by step? It would honestly be the greatest thing ever!
-compressor
-1 double ended SMC solenoid
-2 Pneumatic cylinders
Unread 19-03-2013, 09:26
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Solenoid and compressor help
-compressor
Judging by the fact that you think it is is being caused by code, you should post in the Programming forum for your respective language. (Or at the very least make it clear what programming language you use and what you currently have)
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
Unread 19-03-2013, 09:34
FRC #1846
Sorry i will post there but for the sake of perhaps using some of your expertise i will post the code here aswell can you take a look?
#include "WPILib.h"
//#DEFINE FIRST_SOLENOID 1
class RobotDemo : public SimpleRobot
RobotDrive myRobot; // robot drive system
Joystick stick; // only joystick
Victor Victor1;
Victor SFX_Shooter1_Victor3;
Victor SFX_Shooter2_Victor4;
Relay SFX_Loader_Victor5;
Relay SFX_Tiltmotor; //spike connected to motor
DigitalInput DigitalInput_High;
DigitalInput DigitalInput_Low;
Solenoid Sole1;
Compressor Compress;
//Solenoid Solenoid1;
float Shoot1_Victor3_float;
float Shoot2_Victor4_float;
float Loader_Victor5_float;
public:
RobotDemo(void):
myRobot(1, 2), // these must be initialized in the same order
stick(1), // as they are declared above.
Victor1(1),
SFX_Shooter1_Victor3(3),
SFX_Shooter2_Victor4(4),
SFX_Loader_Victor5(3),
SFX_Tiltmotor(1),
DigitalInput_High(1),
DigitalInput_Low(2),
//Solenoid1(3)
//Relay_Solenoid(2)
Sole1(4,4),
Compress(3,3)
myRobot.SetExpiration(0.1);
* Drive left & right motors for 2 seconds then stop
void Autonomous(void)
myRobot.SetSafetyEnabled(false);
myRobot.Drive(-0.5, 0.0); // drive forwards half speed
Wait(2.0); // for 2 seconds
myRobot.Drive(0.0, 0.0); // stop robot
SFX_Shooter1_Victor3.Set(1.0);
SFX_Shooter2_Victor4.Set(1.0);
* Runs the motors with arcade steering.
void OperatorControl(void)
myRobot.SetSafetyEnabled(true);
Compress.Start();
while (IsOperatorControl())
myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
//Victor1.Set(1.0);
//Shoot1_Victor3_float = 1.0;
//Activates shooter at full speed with button 1
if(stick.GetRawButton(1)== 1){
} else{
SFX_Shooter1_Victor3.Set(0.0);
SFX_Shooter2_Victor4.Set(0.0);
//Actvates loader at full speed with button 2
if(stick.GetRawButton(2)==1){
SFX_Loader_Victor5.Set(Relay::kOn);
}else{
SFX_Loader_Victor5.Set(Relay::kOff);
//Activates tilt in either forward or reverse dependant on button and sensor
if((stick.GetRawButton(4)==1)&& (DigitalInput_High.Get()==0)) {
SFX_Tiltmotor.Set(Relay::kForward);
//SFX_Tiltmotor.Set(Relay::kOn);
}else if((stick.GetRawButton(5)==1) && (DigitalInput_Low.Get()==0)) {
SFX_Tiltmotor.Set(Relay::kReverse);
else{
SFX_Tiltmotor.Set(Relay::kOff);
if(stick.GetRawButton(6)==1){
//Solenoid1.Set(True);
Relay_Solenoid.Set(Relay::kForward);
Relay_Solenoid.Set(Relay::kOn);
}else{
Relay_Solenoid.Set(Relay::kOff);
if(stick.GetRawButton(7)==1){
Sole1.Set(TRUE);
}else{
Sole1.Set(FALSE);
// link
//SFX_Shooter1_Victor3 = Shoot1_Victor3_float;
Wait(0.005); // wait for a motor update time
void Test() {
START_ROBOT_CLASS(RobotDemo);
Unread 19-03-2013, 11:27
Sorry i dont mean to post another thread...
Then why didn't you post in the thread you already started?
That looks like the code you posted originally, before you received advice on what the parameters should be for initializing Solenoid and Compressor objects.
Unread 19-03-2013, 12:30
FRC #1846
I posted that code again because i tried editing mycode and it didnt work! But i have solved it now thank you very much you were a great help!!
