Go to Post overly agressive play, sudden torque gains, and signs of robot acne will cause immediate suspicion, and may be used as justification for a complete tear-down inspection - dlavery [more]
Unread 18-03-2013, 14:28
tim101 tim101 is offline
FRC #4297 (WenoRobots)
tim101 is an unknown quantity at this point
Air Cylinder,compressor,soleinoids,relay
Hey, i really and truly need massive help with this programming.......i have been on this for at least three weeks trying to figure out how to program this air compressor and air seinolds, I've been trying to find someone with the right LabVIEW Functions that shows me exactly how to control the air cylinder,compressor,solenoids,relay: the proper steps on how to program each of the 4 subVI'S that were listed
Unread 18-03-2013, 14:42
jdaming jdaming is offline
jdaming is on a distinguished road
Re: Air Cylinder,compressor,soleinoids,relay
I would start here:
http://www.ni.com/pdf/manuals/372668d.pdf
This is a LabVIEW guide for FIRST robotics (a little old but mostly still good). Chapter 38 will cover solenoids etc.
You can also go to Help>Find Examples and you will find a couple of relevant examples.
If you have specific questions we can answer them.
Worst case come find me during Bayou on Thursday and I'd be happy to help I will be around one of teams 1304,4805, or 4113.
Unread 18-03-2013, 15:39
thanks n i would really to be there but my team and i aren't goin to the Bayou regional this week we are going to the regional in Arkansas
Unread 18-03-2013, 15:58
I am still looking for help
Unread 18-03-2013, 16:14
Racer26 Racer26 is offline
Uh. If you're with 4297, they're registered for Bayou according to FIRSTs website. You can't just change which regional(s) you're going to on a whim.
Unread 18-03-2013, 16:48
Maybe try posting an image of what you have tried so far?
What happens currently when you run the code you are using?
How many solenoids do you have? Do you see any lights change on the 9472 solenoid module in the cRIO chassis?
Unread 18-03-2013, 17:12
Using LabVIEW, you have access to some very good example code and tutorials.
On the left side of the Getting Started window, select the Support tab, then click on the "Find FRC Examples..." link. Browse for the "Solenoid with Compressor" example project (it's in the Pneumatics subfolder under FRC Robotics) and open it. It shows you exactly how to make a compressor work and exactly how to control a solenoid.
One of the tutorials you can find from the Getting Started window is Tutorial 7 - Integrating Examples into Robot Code. That'll tell you how to take the working code from the example and put it into your robot program.
Unread 18-03-2013, 17:52
chriz4gx chriz4gx is offline
AKA: Christopher Villar
FRC #2871 (Beantown Botz)
chriz4gx is an unknown quantity at this point
Hope this Helps!
Are you connecting your solenoids to a relay or the cRio Solenoid Bumper?
Unread 19-03-2013, 11:48
this is my program.
ID:	14387  Click image for larger version
Unread 19-03-2013, 12:11
Thanks for the image.
My other two questions still apply to helping us figure out if the problems is in the wiring, code, execution, etc.
Do you initialize "DoubleSolenoid" in the Begin VI? (I assume you do just want to make sure)
You are expecting it to only go out while you have the button pressed and held correct? Do you see the joystick input on the Dashboard? I am not sure the type of solenoid/how you have it connected but have you tried using reverse instead of forward.
Is your compressor running / do you have pressure when you test this?
Unread 19-03-2013, 12:31
yes i do initialize Double Solenoid in the begin vi
Unread 19-03-2013, 12:44
this is my program.
You labeled it Begin, but the picture is obviously Finish.
So what's the problem? Tell us what you want the robot to do, and what it's doing instead.
Unread 19-03-2013, 12:48
Right now wat I am mostly trying to do is make sure that my compressor is workin
Unread 19-03-2013, 13:01
I'm still quite concerned by tim's Regional confusion.
Whether or not the robot works is irrelevant if they show up at the wrong regional with it.
Unread 19-03-2013, 13:04
So far I have only seen code that deals with the solenoids. Starting the compressor is a separate piece of code have you included that?
I found an image of someone else's begin VI code here with some compressor code in it so you will want to check you have something like that. You could probably also copy the code out of the example mentioned above.
http://www.chiefdelphi.com/forums/at...0&d=1330110193
