Go to Post We don't just build robots. We build people. - Koko Ed [more]
Unread 26-01-2003, 22:05
Iain Iain is offline
Iain is an unknown quantity at this point
How do you connect the speed controller fans?
I did a search, but it never seems to have come up at any other time. I'm part of a completely rookie team, but this is one of the few things that's stumped us so far. Do they just go to the current inputs on the victor? There don't seem to be any other obvious connections on the controller itself other than the PWM input and and break/coast pins.
(Which reminds me of something else - are male ends of the PWM cables supposed to fit into the female connectors on the controller without any modification? I ask because our controllers have this little plastic bump on the inside of the socket that makes it completely impossible to connect them without filing it off.)
Unread 26-01-2003, 22:16
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
We always just crimp rings onto the ends of the leads and connect them along with the power input. As for the PWM cable, you can either file the bump off the shroud on the speed controller or you can file a corner off the cable itself.
Unread 26-01-2003, 22:19
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
That is what Team 930 did last year and plan on it this year.
Yes they do fit. I thaught that at first too. They have a real snug fit so they don't fall out during matches. I spent 2 mins just trying to connect one of those on saturday for our controls board. NO NEED FOR FILING.
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 27-01-2003, 00:26
Andy A. Andy A. is offline
Getting old
FRC #0095
According to IF, the fans are to be wired to the 12v input from the battery (not the output of the victor!). Make sure you get the correct polarity, as the fans may be damaged with reverse and won't acutally cool the FET's when reversed. The fans should run anytime the victor is powered.
Also, there is no keyed version of the PWM cable to fit into the shrouded Victors. Most cables fit in very snugg with a bit of force. If yours really don't fit, trim the black cable terminal, not the Victor!
Shroud or not, I recomend using just a touch of your favorite glue to keep the PWM firmly seated. I've had good luck with just normal elmers glue.
-Andy A.
Unread 27-01-2003, 06:24
Okay, thanks everyone.
Unread 27-01-2003, 07:34
We twist the wires to the fan, trim to length and apply crimp terminals and the attach to the supply side of the controller. Red wire to + terminal of course.
The PWM cables have that little notch because there is a plastic block that you can buy that slips over the connector and holds it in place. They are available from any hobby shop that sells RC parts and do a nice job of protecting the pins.
Unread 30-01-2003, 22:16
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
This is what our team did last year. We solder little pieces of metal which are like 8's and then heatshrink around the solder for insulation.
Pierson C
Team Coordinator
Bellarmine Robotics Team #360
The Revolution
Unread 31-01-2003, 07:05
The new and improved speed controllers now have the locking block built in. Nice job Innovation First!
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Speed controller fan replacement Rickertsen2 Electrical 11 16-01-2003 08:46
Speed Controller Limits yaman Technical Discussion 11 15-01-2003 18:40
Ugh...PWM pin vs. Speed Controller archiver 2001 1 24-06-2002 00:27
making speed controller digital CharlieWilken Electrical 4 01-03-2002 20:15
