Go to Post All hail the amazing duct tape and the mighty zip-tie!!! :] - Gabe [more]
Unread 18-03-2013, 14:07
Anyun Anyun is offline
Co-Captain Team 1308
FRC #1308 (Wildcats)
Anyun is an unknown quantity at this point
Pre-Competition Compiling Issue
Hi guys,
Up until recently I've been using the desktop in our lab to write, compile and deploy code. However, we realized that we will probably need a portable coding station so we installed a Bootcamp partition on my laptop to install Windriver and all the driver software. I imported our project onto the partition, and as a test I compiled it, and received tons of errors. I tried to compile a sample project (the simple robot template), and that didn't work either. Anyone have any ideas?
For reference, the errors I got:
process_begin: CreateProcess((null), svnversion -n .., ...) failed.
This happened while building WPILib, which is of course set as a reference
Then we got
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:1:20: WPILib.h: No such file or directory
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:10: error: expected class-name before '{' token
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:11: error: `RobotDrive' does not name a type
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:12: error: `Joystick' does not name a type
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp: In constructor `RobotDemo::RobotDemo()':
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:16: error: class `RobotDemo' does not have any field named `myRobot'
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:17: error: class `RobotDemo' does not have any field named `stick'
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:19: error: `myRobot' undeclared (first use this function)
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:19: error: (Each undeclared identifier is reported only once for each function it appears in.)
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp: In member function `void RobotDemo::Autonomous()':
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:27: error: `myRobot' undeclared (first use this function)
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:29: error: `Wait' undeclared (first use this function)
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp: In member function `void RobotDemo::OperatorControl()':
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:38: error: `myRobot' undeclared (first use this function)
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:39: error: `IsOperatorControl' undeclared (first use this function)
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:41: error: `stick' undeclared (first use this function)
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:42: error: `Wait' undeclared (first use this function)
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp: At global scope:
C:/WindRiver/workspace/SimpleTemplate/MyRobot.cpp:54: error: expected constructor, destructor, or type conversion before ';' token
C:\WindRiver\vxworks-6.3\host\x86-win32\bin\make.exe: *** [SimpleTemplate_partialImage/Debug/Objects/SimpleTemplate/MyRobot.o] Error 1
Build Failed in Project 'SimpleTemplate' (Process Exit Value was 2): 2013-03-18 14:00:41 (Elapsed Time: 00:00)
I am seriously lost, anyone?
Unread 18-03-2013, 14:09
virtuald's Avatar
virtuald virtuald is online now
RobotPy Guy
AKA: Dustin Spicuzza
Re: Pre-Competition Compiling Issue
Are you sure that you installed the Workbench update for WPILib correctly (you can't just install WindRiver, you need the update too)? It should have placed the WPILib files at C:\WindRiver\vxworks-6.3\target\h\WPILib . If they aren't there.. then that's your problem.
Unread 19-03-2013, 14:42
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
AlexBrinister will become famous soon enough
You rebuilt WPILib? Did you put it in the right directory? That would definitely be your problem.
Alex Brinister
Unread 19-03-2013, 17:40
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
If you are building with the WPILib source, you will need to follow all the instructions here:
http://wpilib.screenstepslive.com/s/...ib-source-code
Looks like you might have some issues with the project references.
Unread 23-03-2013, 23:20
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
To be clear, it shouldn't be necessary to rebuild WPILib in order to install the update, unless you are for some reason modifying it.
Unread 31-03-2013, 13:48
wlmeng11's Avatar
wlmeng11 wlmeng11 is offline
FRC #0008 (Paly Vikings)
wlmeng11 will become famous soon enough
You could also try using UCPP to build on OSX directly.
