Go to Post FIRST gives everyone lots of practice in getting used to late nights. - waialua359 [more]
Unread 19-03-2013, 20:47
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
Re: Full court shooting strategy
Well, think about the maneuverability you lose with an 84 inch robot. Bots who just tack that kind of height on become unbalanced, and they tend to tip. Plus, most full court shots come out fast, and unless the blocker is big and heavy, it causes damage.
Unread 19-03-2013, 20:52
FRC #1836 (MilkenKnights)
Not true at all. pool noodles are super light and if you put some kind of fiberglass rod inside the pool noodle it should be a very good defense against full court shooting.
Unread 19-03-2013, 20:58
AKA: Wren Hensgen
I am just saying what I saw from Chestnut Hill. 4454, a rookie team, added a perfectly strong blocker, pool noodle over plywood, but it upset their CG
Unread 19-03-2013, 21:01
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
Originally Posted by Jeffy View Post
I'm very surprised most teams aren't taking advantage of the 84 inch rule when making an "on the fly" wall bot.
Seems a bot with a wide appendage at 84 inches would block any shot.
G22
ROBOT height (as defined in relation to the ROBOT) must be restricted as follows during the MATCH:
If in contact with the carpet in its AUTO ZONE and/or its PYRAMID, ≤ 84 in.
Otherwise, ≤ 60 in.
You cross the carpet at the edge of the pyramid (outside the auto zone) and it is a foul, a technical if you keep doing it. Not exactly a good strategy for an "on the fly" modification. You are trapped and can't load disks, not that you had been shooting any in the first place.
Now, if you built a wallbot that could raise and lower it's wall from 84" to <60", that may work. Just don't leave the AUTO ZONE while you are extended.
Unread 19-03-2013, 21:17
holygrail's Avatar
holygrail holygrail is offline
Gavin Wood
FRC #1939 (The Kuhnigits)
holygrail is just really niceholygrail is just really niceholygrail is just really niceholygrail is just really nice
1806 was the most feared bot at the Kansas City Regional because of their versatility. They were hitting high percentage 3 point shots from full court, then if you blocked them, they would just run cycles at the pyramid, then climb for 20 and dump for 20 more. It had everyone in a panic trying to figure out how to defend it. I would be surprised if they didn't make it pretty far at Championships.
FIMAlumni's Avatar
FIMAlumni FIMAlumni is offline
FIMAlumni has a spectacular aura aboutFIMAlumni has a spectacular aura aboutFIMAlumni has a spectacular aura about
I would be very interested to see a very high profile/high arcing shooter such as 3604 paired with a very long robot such as 326 parked in front of them. This pair to me seems like it would be able to empty all feeder station discs with hopefully and ground pick up bot to clean up the early missed shots.
Unread 19-03-2013, 21:48
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
something the judges, at least at st louis, did not do well was the 84in rule for outside the auto zone. Wonder if that rule has been interpreted the same at other regionals.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 19-03-2013, 21:51
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
We made our shooter harder to defend actually...
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 19-03-2013, 22:04
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
How about this particular scenario:
An alliance elects to use 2 Full Court Shooters, one on each side of the field. The third alliance partner is playing defense or scoring via discs on the floor. If the opposing alliance decides to block both Full Court Shooters, would this result in a blockading/stopping the flow of the match penalty under G25?
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 19-03-2013, 22:06
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Were they not calling violations for robots > 60" completely outside of the auto zone, or do you mean something else? I'm having trouble parsing your post.
Mentor http://www.teamtitanium.org/
Unread 19-03-2013, 22:08
There should be no problem stopping the FCS on the single-load side of the field; there's no protected area. No blocker needed; just bash them off their loading spot.
AKA: Nicholas
FRC #0313
I believe it may..
Unread 19-03-2013, 22:09
John Sabath's Avatar
John Sabath John Sabath is offline
LabVIEW Software Developer
FRC #3792 (The Army Ants)
John Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to behold
They were calling them. I'm not sure what he means either.
Freshman at Missouri S&T ( Computer Science )
FRC 3792 (The Army Ants) from 2012-2013
Unread 19-03-2013, 22:16
AKA: Carl Springli
Easier said than done in some cases. Plus, in doing so, you would essentially be preventing the shooter bot from leaving its loading zone while also blocking the one on the other side of the field. This might be even more of a G25 penalty.
Unread 19-03-2013, 22:25
Not sure how other regionals will call it, but in St. Louis you could really only blockade the protected feeders. As long as a theoretical route is open, then it's not blockading, even if none of the robots can take advantage of said route (such as going under the pyramid).
One of our defensive strategies was to place a robot on each side of the pyramid to prevent the other alliance from feeding their full-court shooter. No G25 violations.
I'd talk to the head-ref at each event to figure out what you can get away with, because it is up to interpretation.
