Go to Post I think the answer you will get will be the same we have been saying since post #2 on page 1. - KenWittlief [more]
Unread 10-03-2013, 03:34
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
OpenCV + ffmpeg hangs at low resolutions and low framerate
In case anyone is using OpenCV + ffmpeg to do their image processing, I found a bug in OpenCV that causes ffmpeg to hang for up to 30 seconds or so when trying to connect to the AXIS M1011 camera. I'm surprised the SmartDashboard doesn't run into this problem, since it appears to use ffmpeg underneath the hood for capturing with camera extension widgets (but not for the default camera widget that comes with it).
If you're interested in more details, check out the bug reports at OpenCV and FFMpeg.
Unread 10-03-2013, 23:26
gluxon's Avatar
gluxon gluxon is offline
\n
AKA: Brandon Cheng
FRC #0178 (The 2nd Law Enforcers)
gluxon has a spectacular aura aboutgluxon has a spectacular aura aboutgluxon has a spectacular aura about
Re: OpenCV + ffmpeg hangs at low resolutions and low framerate
Around the start of this year's build season, I contacted Spectrum 3847 about using OpenCV on an onboard Raspberry Pi for vision processing. They replied describing a problem with ffmpeg and OpenCV causing significant lag. It is probably the same issue you found above.
Well, a few months later and here I am. I created a fully working Node.js based OpenCV processing server. I'm using the Axis VAPIX Video Streaming API (which is just MJPG over HTTP) and it's giving me 25 processed target images (640x480) per second. I created node-vapix to implement this and interface with the camera and I'm using node-opencv for OpenCV bindings.
This entire time, I never even had to introduce FFmpeg into my project. So I'm asking, why even use OpenCV's VideoCapture instead of directly providing images?
oculus.js: https://github.com/team178/oculus.js
node-vapix: https://github.com/gluxon/node-vapix
node-opencv: https://github.com/peterbraden/node-opencv
Unread 11-03-2013, 22:17
virtuald's Avatar
RobotPy Guy
Cool stuff. Of course, I've already put in the effort to fix the problem with FFMpeg (and it is fixed, after changing the source code a bit), so I'll stick with that for now until it bites me again.
Unread 13-03-2013, 04:06
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Im so glad to hear 1706 isnt the only team using OpenCV. We use the microsoft kinect though with illuminators (as of this year). Good luck!
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 20-03-2013, 19:39
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I am just starting down the road to learning how to use OpenCV with a webcam through Linux. I HAVE NO CLUE right now what I will be facing. So, can you possibly provide tips on what to look out for, gotcha's to avoid, things that worked and things that didn't? I would hate to reinvent the wheel when the work has already been done.
So, what caused the OpenCV + ffmpeg issues and how did you resolve it?
Unread 20-03-2013, 19:43
faust1706's Avatar
Just make sure whenever you call functions such as cvCreateWindow and cvCreateMemStorage, you get rid of them too at the end.
Unread 05-04-2013, 11:39
virtuald's Avatar
RobotPy Guy
To fix it, you have to add a line to the OpenCV source code and rebuild it. Check out the bug reports referenced above for more information.
