Go to Post Breathe in and out.... *altoids mint* breathes in more... *looks at countdown until kickoff*...30 DAYS!!! *competition anxiety disorder* - Conor Ryan [more]
  #31   Spotlight this post!
Unread 20-03-2013, 08:39
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Re: Airzooka
Originally Posted by dtengineering View Post
and using divine intervention to improve autonomous mode.
Hey, it works! Our team always does magic fingers to encourage a successful auton.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
  #32   Spotlight this post!
Unread 20-03-2013, 08:40
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Re: Airzooka
Originally Posted by Kevin Sevcik View Post
I'm reminded of Lisa Simpson's tiger repellant rock. First you have to convince me that the robots in that match were actually capable of consistently hitting 3-pointers. Then I might be willing to believe that fan was capable of deflecting hard thrown pyramid shots.
1648 was missing low shooting over that. Combine that with the autonomous results and I must conclude that any nearby tigers are in hiding.
Mentor http://www.teamtitanium.org/
  #33   Spotlight this post!
Unread 20-03-2013, 09:05
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Airzooka
Even after it has worked consistently all day I still find myself crossing every appendage that I can. I've tried to get other team members to do it, also. My thought is that if we will it hard enough it will suddenly have the most advanced autonomous available and all of the frisbees on the field will just fly into our loader.
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
  #34   Spotlight this post!
Unread 20-03-2013, 15:08
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Airzooka
First off, you can't compare a hand-aligned, fixed position autonomous shot with a teleop shot lined up in the open field with (apparently) no automated targeting. Autonomous accuracy is much likely to be higher than teleop.
Second, it sure looks like 1648 was missing high for the first volley, then low for the second volley. One would expect a fan would cause consistent high misses.
Sadly, there isn't footage there of 1648 shooting without the fan in front of them. If I had some evidence that 1648 was dead accurate in teleop without that fan, then I would certainly believe the fan was having a significant effect.
  #35   Spotlight this post!
Unread 20-03-2013, 17:15
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
Re: Airzooka
You can clearly see the frisbee being pushed up and missing high on the first 3 teleop shots. They only miss low after changing positions to the side of the pyramid, and they have to back up to find a good spot to shoot from.
EDIT: https://www.youtube.com/watch?v=E5Gu8q9ODBU in this match I counted 9 for 12, in 3 cycles (3,4,2 respectively).
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
  #36   Spotlight this post!
Unread 20-03-2013, 20:30
Re: Airzooka
Originally Posted by Lil' Lavery View Post
I don't know of any teams using them this year.
http://www.chiefdelphi.com/media/photos/38644
You have now been informed of a VERY LARGE fan mounted on a robot by an FRC team. (How it did, I don't know offhand.)
  #37   Spotlight this post!
Unread 21-03-2013, 09:18
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Airzooka
Now take a look at their competition robot.
http://www.youtube.com/watch?v=Yy4iNwGEb3k
  #38   Spotlight this post!
Unread 21-03-2013, 19:45
Re: Airzooka
Ah, so they were having a little fun with the posted picture. Wonder if they were testing their shooter against it, on the chance that someone would try it.
  #39   Spotlight this post!
Unread 21-03-2013, 22:27
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Airzooka
I saw them unbag at Traverse City. "Where's the fan?" It was just a joke. The picture was supposed to infer that they could fly to the top of the pyramid.
(since 2004)
  #40   Spotlight this post!
Unread 21-03-2013, 22:51
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
Re: Airzooka
We were testing our ability to fly to the top of the pyramid.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
  #41   Spotlight this post!
Unread 21-03-2013, 23:00
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Re: Airzooka
After that match, I talked to the drivers, and they confirmed that despite the aiming light shining in the sweet spot, the shots were going high as a result of the fan, and when changing positions on the 2nd cycle, they shot thinking "fanbot" was in the way, when it wasn't.
After we got back from palmetto, our students were still riled up about the "fanbot", so much so that they voted to install a fan on the top of the bot, but common sense took over and told them to improve the shooter so that fans wouldn't be a problem in the first place. However, one of our mentors brought a fan into Peachtree as part of our withholding allowance, just in case there was a Dozer on our eliminations alliance .
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
  #42   Spotlight this post!
Unread 22-03-2013, 15:43
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Airzooka
Originally Posted by Akash Rastogi View Post
I don't have a picture, but I'm almost 100% positive 869 has a giant fan on their robot.
From TCNJ:
  #43   Spotlight this post!
Unread 22-03-2013, 18:11
compboy07's Avatar
compboy07 compboy07 is offline
AKA: Jake M.
FRC #2449 (Out of Orbit)
Team Role: Electrical
compboy07 is on a distinguished road
Re: Airzooka
No pics here either, but our team also had a giant fan (22" COTS with custom duct and a CIM).
The problem was that you needed to have a significant distance between the fan and the goal and the other robot had to actually be able to shoot over the bot for it to be of much use. We achieved infamy in our regional, but took it off because only about 2 teams had a robot that could shoot over another from midcourt or the other side. The fan had little impact on close range, so we mounted our half-finished shooter instead.
Also: the duct had blinking leds in it. It was epic.
