Go to Post to have someone honored as being honered next to us is a huge compliment thank you lol - Aren_Hill [more]
Unread 20-03-2013, 23:11
aechmtwash11 aechmtwash11 is offline
FRC #2783
aechmtwash11 is an unknown quantity at this point
Loading Zone - Max Height
What would be the max height a robot could be while in its loading zone?
I would assume 60" because you are outside of the team's autozone.
Unread 21-03-2013, 06:36
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Loading Zone - Max Height
Correct.
If you're in the loading zone and still in contact with your pyramid or auto zone, you are WAY outside that 54" cylinder.
(since 2004)
Unread 21-03-2013, 08:41
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Not sure what the 54 cylinder has to do with it. Once no longer contacting your auto zone carpet you limited to 60". Your loading zone is a long ways from that.
Unread 21-03-2013, 09:10
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
That's exactly his point. If you are somehow touching both the loading zone and your own auto zone/pyramid, you will have extended beyond the 54" cylinder.
Unread 22-03-2013, 01:14
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
If you are in your own loading zone you can extend to 84 inches
Unread 22-03-2013, 06:22
GaryVoshol's Avatar
Cogito ergo arbitro
No you cannot.
If I'm wrong, please cite the rule.
(since 2004)
Unread 22-03-2013, 08:24
CooneyTech CooneyTech is offline
FRC #0269
CooneyTech is an unknown quantity at this point
While in yiur loading zone you can be a max a 60in. but if you are in your pyramid zone where your goals are you can go 84in.
Unread 22-03-2013, 09:08
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Originally Posted by GaryVoshol View Post
No you cannot.
3.2.5.1 G22
ROBOT height (as defined in relation to the ROBOT) must be restricted as follows during the MATCH:
A. If in contact with the carpet in its AUTO ZONE and/or its PYRAMID, 84 in.
B. Otherwise, 60 in.
Violation: FOUL. If continuous or repeated violations, TECHNICAL FOUL.
3.2.5.2 G23
A ROBOT’S horizontal dimensions may never exceed a 54 in. diameter vertical cylinder.
Emphasis added.
There were some add-ons for G23 to address the cylinder relative to pyramid climbing, but the essence hasn't changed.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
