Go to Post I have gone and confused myself again. Why does this happen every time? - Jay Trzaskos [more]
Unread 21-03-2013, 21:47
austpet1230's Avatar
austpet1230 austpet1230 is offline
FRC #4459 (Leotechs)
austpet1230 is an unknown quantity at this point
Question Initializing and Using Buttons to Control Victor Motor Controllers
Hello everyone, I have made a thing to use buttons 4 & 5 to control the servo motor to our Axis camera. The servos are connected to the PWM channels and we just need to program the motor. Would the following code work to accomplish our task?
#include "WPILib.h"
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive system
	Joystick stickRight, stickLeft; // only joystick
	Victor (victora);
	Victor (victorb);
	Victor (victorc);
	Victor (victord);
public:
	RobotDemo(void):
		myRobot(victora, victorb),	// these must be initialized in the same order
		stickRight(1),		// as they are declared above.
		stickLeft(2),
		victora (1),
		victorb (2),
		victorc (3),
		victord (4)
		myRobot.SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous(void)
		myRobot.SetSafetyEnabled(false);
		while (IsAutonomous()) //drive commands continuously loop
		myRobot.Drive(-0.5, 0.0); 	// drive forwards half speed
		Wait(2.0); 	                // for 2 seconds
		myRobot.Drive(0.0, -0.5);   // Turn
		Wait(1.0);					// for 1 second
		myRobot.Drive(0.0, -0.5);   // Turn again
	 * Runs the motors with arcade steering.
	void OperatorControl(void)
		myRobot.SetSafetyEnabled(true);
		while (IsOperatorControl())
			myRobot.ArcadeDrive(stickRight); // drive with arcade style (use right stick)
			Wait(0.005);				// wait for a motor update time
			if ((stickRight->GetRawButton(4) == 1))
				Intakevictorc->Set(.7f);
			else if (stickRight->GetRawButton(4) == 0)
				Intakevictorc->Set(0.0f);
			if ((stickRight->GetRawButton(5) == 1))
				Intakevictord->Set(-.7f);
			else if (stickRight->GetRawButton(5) == 0)
				Intakevictord->Set(0.0f);
	 * Runs during test mode
	void Test() {
START_ROBOT_CLASS(RobotDemo);
Thanks for your help!
If you haven't found it yet, keep looking. Don't settle. As with all matters of the heart, you'll know when you find it. And, like any great relationship, it just gets better and better as the years roll on.
-Steve Jobs
R.I.P. Steve Jobs 1955 - 2011. The Greatest Innovator of all time.
Unread 21-03-2013, 23:31
Re: Initializing and Using Buttons to Control Victor Motor Controllers
You titled your note with "Victor Motor Controllers", but you asked about "the servo motor". I don't see any servos in your code. What are you really trying to control?
Why do you have parentheses around the names of your Victor objects when you declare them?
You declared "victorc" and "victord", but you're trying to set "Intakevictorc" and "Intakevictord".
If you fix the names to match, your code will run motor C on PWM 3 forward when you press button 4, and motor D on PWM 4 backward when you press button 5. It never runs those motors in the other direction.
Unread 22-03-2013, 16:52
Sorry, I meant to ask about the servo motors not the victor motors. If one were trying to initialize and use the servo motors would it be initialized like this (initializing two servos):
        Servo (servoa); //Initialize servo 1 (or a)
        Servo (servob);  //Initialize servo 2 (or b)
and if this is correct, then how would one go about programming these to buttons? Could this code work?
//Example code
		servoa->Set(.7f);
		servoa->Set(0.0f);
Thank you for your help.
-Steve Jobs
