Go to Post It moves so smoothly because it is magic. - dtengineering [more]
Unread 21-03-2013, 07:24
austpet1230's Avatar
austpet1230 austpet1230 is offline
FRC #4459 (Leotechs)
austpet1230 is an unknown quantity at this point
A few questions about C++
Hello everyone,
I am part of a rookie (well not anymore) team and in the 2014 FRC Competition, we plan on using C++ to program the robot.
My first question is C++ or Java better to program in?
My second question is that is this code appropriate to initialize two joysticks?
#include "WPILib.h"
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive system
	Joystick stick1, stick2; // only joystick
public:
	RobotDemo(void):
		myRobot(1, 2),	// these must be initialized in the same order
		stick1(1),		// as they are declared above.
		stick2(2)
		myRobot.SetExpiration(0.1);
Thank you to everyone and anyone who answers my question.
Austin P. //Programming Captain | The Leotechs FRC#4459
Unread 21-03-2013, 08:57
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: A few questions about C++
C++ and Java are extremely similar. I'd recommend you go with whichever language you're more familiar with.
Yes, that code is a reasonable start at making a driveable SimpleRobot.
Whether you're using C++ or Java, I'd highly recommend you take a look at Command Based Programming with the CommandBasedTemplate. You end up with more files, but I think it makes building autonomous routines and automated functions a good bit easier. Once you get basic commands set up, it's incredibly simple to tie them together an autonomous routine like aim and fire 3 frisbees, switch to loading position, turn 30 degrees and back up 5 feet. And then build another routine that does other things.
Unread 21-03-2013, 09:30
Tanaythan's Avatar
Tanaythan Tanaythan is offline
Programmer
AKA: Tanay Nathan
FRC #3256 (Warriorborgs)
Tanaythan is an unknown quantity at this point
Similar to the previous post, C++ and Java are very similar and it's a matter of preference. However, my take on the Command Based robot is it's good for new people to C++ so it makes it easier to develop a multi-file project. So, because you're switching to it next year, you should use it as a starting point. Once you become more proficient in C++ development, I highly suggest you write the code from scratch to develop yourselves as programmers and as a learning process.
Tanay Nathan
Programmer
Team #3256 Warriorborgs
Unread 21-03-2013, 11:10
Mastonevich's Avatar
Mastonevich Mastonevich is offline
Andrew
AKA: Andrew Elsen
FRC #1987 (BroncoBots)
Mastonevich is a jewel in the roughMastonevich is a jewel in the roughMastonevich is a jewel in the rough
Java was written with C++ used as a base in many instances so they are very similar. For FIRST robots, you would find that you could port your code from one to the other fairly easily. The underlying WPI library has all of the same classes and functions.
While I am a huge fan of the command based robot, I believe that some new people may have trouble with it. It some instances it may be best to start with the simple or iterative template to get the feel for it, but then move to the command based.
I will say we had all new programmers this year, and we are using the command based robot. We had several programming mentors though that were there to help through the stumbling blocks. After it was all said and done, our students seem to love the advantages. Changing our code is a breeze now, where as without the command based robot it would take much longer. You can not get any easier coding for autonomous, the toughest part of coding a FIRST robot.
In answer to Java or C++, pick one and go. As far as FIRST robots go, neither will really be easier or better than the other in my opinion.
~Andrew
Regional Chairman's: 2013-Alamo, 2010-Oklahoma, 2009-Colorado
Engineering Inspiration: 2016-Hub City, 2012-St. Louis, 2008-Minnesota
Regional Wins: 2010-Oklahoma
Unread 21-03-2013, 20:35
Thank you for all of the responses!
Unread 21-03-2013, 21:06
Just have one more question... How would one go about modifying the speed that the robot moves when the joystick is fully pushed forward in Teleop mode, like in Autonomous, the speed is set
myRobot.Drive(-0.5, 0.0);
is there a teleop version of this (if that makes sense)
Unread 22-03-2013, 00:56
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
probably something like
myRobot.TankDrive(Stick1->GetRawAxis(2)*.5 , Stick2->GetRawAxis(2)*.5);
I'm not sure which axis is which for your controller (where the number 2 should be substituted with the Y axis of your controller for tank drive). I'm also not sure that you're using tank drive Just multiply your joystick value by whatever you want to reduce the speed by, regardless of whether you're using arcade or tank or holonomic or whatever.
Unread 22-03-2013, 04:59
Thank you!
If you haven't found it yet, keep looking. Don't settle. As with all matters of the heart, you'll know when you find it. And, like any great relationship, it just gets better and better as the years roll on.
-Steve Jobs
R.I.P. Steve Jobs 1955 - 2011. The Greatest Innovator of all time.
Unread 23-03-2013, 23:19
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Looking at the code for RobotDrivie, it looks like you can also say
myRobot.SetMaxOutput(.5)
to apply a global factor to your drive output.
I'm a big fan of the command-based robot framework, even for sophisticated teams. It makes the robot code much easier to understand.
Unread 24-03-2013, 14:30
thank you!
-Steve Jobs
