Re: Kitbot wheel durability
Our KOP wheel broke exactly the same way at Waterford when Team 67 hit us sideways. It was only our 7th match. The students switched it out very quickly because of our design. I now have quite a few of them ready in case it happens again.
This was a fairly standard failure of the older skyway wheels, which I believe were the basis of the new traction wheel. I seem to remember a lot of them failing in 2007.
The hub failure I referenced earlier, Tom. Essentially, repeated heavy side loads could cause the hub to tear away from the spokes. (469's swerve and 330's rear wheels in a 6WD skid took quite a beating--Mark picked up one in the process of failing after San Diego eliminations.)
![]() Lenape district, 87 had us cornered and continued to drive into us, I'm guessing they have an amazing drive because they drove up our bumpers and landed on our drivetrain and were stuck in tow for the majority of the match. Once they broke loose we noticed our robot would shake violently when we tried to drive, turns out it was from this. Not sure if it was the initial impact or something from towing them around, but this is the result. Also, 1. no penalty was called for them clearly being latched onto our robot and being towed around 2. no penalty was called for damaging our robot 3. no penalty was called for contacting us as we were attempting to shoot while touching the pyramid. what gives? |
We broke 3 of these. We finished the last round of the finals with only 5 wheels. It could have cost us the Sacramento Regional. Will be talking with AndyMark.
