Re: Custom Pixel-By-Pixel Vision Processing
Last year one of our students wrote image processing code in Java.
We used the command based robot template. The camera Code resides within a subsystem. The code is available here for reference: https://gist.github.com/jcorcoran/5228621 Hopefully that helps get you moving in the right direction. Something to watch out for is performance. The frame rate can get pretty low for image processing running cRIO side. You may want to look at performing your vision processing using openCV through the smartdashboard. Vision processing code would run on on your driver station laptop in this case. There are plenty of good resources on driverstation side image processing code. http://www.chiefdelphi.com/forums/sh...ght=341+vision https://code.google.com/p/frc2012-te...i/VisionCoding |
I'm curious what you find sloppy about nivision?
Greg McKaskle |
I don't find the NIVision libs sloppy; just unusable for any complex operations. So far as I know and have experimented, there is no way to interact with NIVision.Image type images except through NIVision methods. Also, there's no way to create NIVision.Image type images other than with a webcam. Not only does this drawback leave many (including me) with no option other than using external libs, it makes CameraServer, which is compadible only with NIVision.Image images, useless. Please, if I'm wrong, correct me. I would like to use the utilities provided by default if I can.
2. Have you seen imaqCreateImage? Or the (somewhat useful) documentation in Program Files\National Instruments\Vision\Help? 3. It's really not that hard to implement CameraServer yourself. It's literally just the bytes 1 0 0 0 followed by a 32 bit integer n, followed by n bytes of a jpeg image. Over and over on a tcp stream |
