Re: Falcon Scouting System Release
I am still having trouble installing the scouting program. I am using Windows 7 Ultimate and the version of SlimDX that you posted. For some reason it is installing as 2.0.13.43. I am getting this error message after I hit "Install" in the setup for MultipleJoysticks that says "Unable to install or run the application. The application requires that assembly SlimDX version 4.0.13.43 be installed in the Global Assembly Cache (GAC) first." We have been trying to fix this and have already reinstalled Windows on two computers. What should we do?
We've also had that the GAC issue on several PCs I finally got one PC to do load the programs. I can get the sorter to work, but when I click on MultipleJoysticks, which I assume is the program to run the scouting program, I get nothing. A window opens up that says "verifying application requirements, this may take a few minutes" and that is it, nothing else, when I click on the sorter program, I get a screen similar to what you show in your screenshot, but nothing for the scouting program. Any help would be greatly appreciated! Thanks for all your hard work.
Yes I have done all of this on a fresh copy of windows. I got the program to work fully on our driver station computer running windows 7 home premium, but we need that for driving. Do you think there is something about windows 7 ultimate that causes this problem?
Sergio--Do you have scouting data from the Galileo division at Championships? If so, would you mind posting it here?
#7
Yes but some of it is unreliable due to human error (Some matches were not saved properly and some zeros are placed where they shouldn't be). I can still post what I have.
#8
is there no 2014 update? just curios it seemed to be a very good scouting system.
#9
There is. I am having some last tweeks made on it then I will release it.
#10
Almost done tweaking the system?
