Go to Post Relax. Have fun. Enjoy the improvements. Build what you want to. - Rich Kressly [more]
Unread 23-03-2013, 22:15
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Robot Code Deplyoment
Originally Posted by brennonbrimhall View Post
Could you clarify your question?
Originally Posted by ykarkason View Post
It seems logical that the cRIO's flash memory is somewhat limited, and using it and reusing it will eventually kill it, so... is it the correct behavior?
Flash memory is rated for a number (usually in the 10,000s) of write cycles before the memory might fail. Sounds like the OP is asking if there's a way to run Java code on the cRIO without writing to the flash memory to extend the life of the cRIO.
FRC 766, 2015-, Mentor
