Go to Post Do you know how, say, Native American cultures were kept? They had storytellers, sages, and the like. They passed on their legends and culture to the next generation. So will we. - EricH [more]
Unread 23-03-2013, 21:12
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Teleop Limit Switch Firing Sequence
Hey everyone, currently our robot has an arm that when a button is pressed, a sequence of shooting in cocking for next shot occurs. This has worked....... at times, during some of our matches at Mt. Olive District Event, we noticed that if the arm got jammed on a frisbee, it was unable complete this sequence and our robot would not be able to shoot. We would like to know if anyone has a suggestion on improving this code so that it would exit the sequence structure if this would happen. I posted what we currently have. Thanks
Unread 23-03-2013, 22:04
Re: Teleop Limit Switch Firing Sequence
The way it is written, the first loop will run at full speed until the limit switch is triggered.
You may want to combine the exit condition with a timeout. OR the limit switch and either a loop counter or a time since the loop began. You may also want to throttle the loop by putting a delay in it.
The attached image shows the sort of thing you might do.
Greg McKaskle
Unread 23-03-2013, 22:19
Ahh thanks Greg, why should this be done in the first loop and not in the second or should I do this also in the second loop?
Unread 23-03-2013, 22:38
If I were you, I'd do something similar in the second loop as well. I was just giving an example.
Greg McKaskle
Unread 23-03-2013, 22:41
Ohh ok, thanks, will try this in the AM!
