Re: Build Error(s)
The FRC2013 project seems like it's not a robot project, based on the target directory.
For the errors in SimpleTemplate, I'd try to do clean and then build as a first step. |
Re: Build Error(s)
I thank you for trying to help me but I am completely new to WindRiver and do not understand all the functions. So a lot of 'hand holding' and /or pointing me where to read would be very helpful. |
Re: Build Error(s)
Has your machine ever successfully built a C++ robot program? I haven't seen this pattern before, but it smells a bit like some sort of installation issue.
Re: Build Error(s)
It looks like you're building the wrong kind of project. The build indicates that you're trying to build a .exe which would be a native project instead of a VxWorks 6.x Downloadable kernel Module Project. Try to start from a clean workspace and do a New->Example->VxWorks Downloadable Kernel Module Project->FRC Simple Robot Template. Once you create the project, right click on the project and select Build Project. Hopefully it will build.
HTH, Mike |
Re: Build Error(s)
Steve,
Yes this version of WindRiver with the required update has worked before in Building, Deploying and then running the Bot via the 2013 Driver station. The error now is from the same source that worked before we moved it (source) to a new directory. Mike, I try your suggestion after sign off. |
Re: Build Error(s)
Hi Mike,
Thank you very much for the input. After we right clicked and deleted all the current projects and then followed your suggestion we back up and running again. |
