Go to Post I actually see no issue about the sentence, but then im still in college and only half way edumacated, i am only eduma right now. - Alex Cormier [more]
Unread 24-03-2013, 07:39
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Alternative motors for drive train
Some teams have used motors to supplement CIMs, including the Fisher Price motor, AM-9014, RS-550 and 775, BAG, and Mini-CIM, often to great success. I've never heard of a drive with no CIMs having anything but problems. Not only is the CIM the most powerful motor in the kit, it is also the best at handling the stall conditions and tremendous amounts of heat buildup inherit to drive train applications.
Unread 24-03-2013, 12:33
EricH EricH is online now
Actually, yes.
Unfortunately, I've been around a while. So this one isn't going to be legal anytime soon...
Two Bosch drill motors, running through somewhat modified Bosch drill transmissions, one on each side of the robot. (Note: While we rarely had an issue, many teams did have issues.) 4WD, all powered. Hasn't been legal since 2004, due to the drill motors being replaced by a pair of CIMs in the 2005 and later allowed motor lists; CIMs had been included for at least a few years before then along with the drill motors.
You could also ask Billfred about driving using window motors.
Unread 24-03-2013, 13:56
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
I know that 1218 last year used a hybrid RS775/CIM drivetrain so they could use their CIM elsewhere. It definitely degraded their pushing power and gave them a little trouble on the bridge.
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
3824 at Palmetto was powering a meccanum drive off 4 mini-cims in toughboxes. It was fast, but was on the short end of the stick when it came to defense.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 24-03-2013, 14:04
Ivan Malik's Avatar
Ivan Malik Ivan Malik is offline
Any other Anthropologists out there
Ivan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant future
2009 saw some interesting designs due to the field surface... It would be a good place to look. I cant recall any off the top of my head save for robostang's crab that turned the wheel pods using servos.
FRC Student: 2007-2010 ~ FLL Mentor: 2007-2009, 2012 ~ FIRST Volunteer: 2012-present
Scouting, Chairman's, Mechanical, Business, Community Outreach, anything that doesn't have wires or code, but I dabble.
Unread 24-03-2013, 14:44
Joining the 900 Meme Team
FRC #0079
2337 attempted to use FP motors in their drive. It didn't end too well as I recall.
Unread 24-03-2013, 15:05
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
In 2007 118 used a "v6" transmission for their swerve drive Video while they did use 4 CIMs, they had two smaller motors supplementing them (I'm not sure what kind).
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 24-03-2013, 15:13
FRC #1836 (MilkenKnights)
This year we're running a 4 CIMs and 2 550s on our drive. It gave us quite a bit of pushing power to push around almost all of the teams at the Israel and LA regionals.
Unread 24-03-2013, 15:48
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
They were the fisher price motors.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 24-03-2013, 18:53
Yep.
In 2006, 968 ran 2 CIMs and 1 FP in each drive transmission (or was it 1 and 1? I forget.). Anyways, I recall that they got quite a bit of practice in changing FPs out of the trannies due to frying. Something about FPs (and most of the KOP non-CIM motors) not exactly handling stalling very well.
I've used 4x RS775 motors in a drive, but there was almost no pushing involved, and weight was a very definite factor (as in, lower the weight for better points). This was not an FRC robot, BTW.
Unread 25-03-2013, 14:33
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
This. I know on 498 that year we used 1 Banebots motor and transmission per side for our drive (I think RS550s). Never had any problems but I wouldn't do it for any "normal" FRC game. We also had to be careful to not drive the robot on carpet ever as a result.
Unread 25-03-2013, 14:38
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
With the recent flexibility in the use, number, and types of motors, I cant see why anyone would use anything other than CIMs in their drivetrains as their main source of power..........other than weight issues.
In 2010, we had a pretty tough drivetrain that allowed us to play striker in all of our tournaments. Oddly enough, we used only a 1 CIM/1 FP (AM planetary gearbox) drive on each side to push robots around. We did it to shave off weight during crunch time of build season.
That year we had I believe a 47 match win (non-loss) streak including the ties.
Unread 25-03-2013, 14:46
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
As John mentioned, we have mini-cims for our drive this year. I believe this was done primarily for weight issues, as our design is a corner climber-dumper. We are using custom 1-speed gearboxes.
I'm a software guy so to me it's all -1.0 to 1.0, but I'll see if I can get someone who worked on it to talk about ratios and such.
Unread 24-03-2013, 19:37
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
1675 also used 4 mini-cims for their meccanum drive. I'm not sure their specific set up, but I was actually impressed with their pushing/defense (for a mecanum drive that is )
Unread 25-03-2013, 10:00
Andy A. Andy A. is offline
Getting old
FRC #0095
Two 3/8ths drill motors, geared for a blazing 8 feet per second. Then again, 8fps was pretty fast when no one had heard of bumpers yet.
It's really impressive how far FIRST drive trains have come.
