Go to Post "its not working because you didnt program it right" *wheel falls off* "never mind" - Nin_estarSaerah [more]
Unread 24-03-2013, 07:43
RoeeVulcan's Avatar
RoeeVulcan RoeeVulcan is offline
With burning passion ;)
AKA: Captain Mortenfeld for you
FRC #3835 (Vulcan)
RoeeVulcan is just really niceRoeeVulcan is just really niceRoeeVulcan is just really niceRoeeVulcan is just really nice
Bumper Restrictions
During our inspection problems kept coming out with the way we did our bumpers. In result i have two questions:
1) Where can i see a list with the full bumper restrictions? Do any of you have one? I remember searching for one with the height of the ground our bumpers can have, without any luck in the manual, and than having it on the inspectors list.
2) Have the bumper rules ever change since they were first introduced? Is there a possibility that a solution for the bumpers i will find this year be banned by the next?
That's Captain RoeeVulcan for you.
israeli 2013 finalist
Unread 24-03-2013, 08:09
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Bumper Restrictions
Please check section 4.1.6 of the manual for bumper rules:
http://frc-manual.usfirst.org/viewItem/3#4
R03 also defines the frame perimeter wich is important to the bumpers.
Each year, many of the rules change a little bit or a whole bunch. The bumper rules have been around since 2005, with continuous refinement. In 2010, the FRC Game Design Commitee switched over to the Red/Blue configurations with numbers on them. Often there is a change in height from the ground and whether they must be continuous or may have gaps. It would seem that these changes are primarily dependent on the game pieces and how they want the game to play.
Bumpers can be a very frustrating part of the inspection process. There are a lot of detailed rules that must be followed. Often teams that have the most trouble are focusing their design at the limits of the rules. IE, if the bumper length mus be 8" from the corner, they make that segment 8". Unfortunately if the cut is slightly short, of the bumpers don't fit tightly, you can end up in a condition where your bumpers are only 7 3/4" from the corner of the frame perimeter, and thus non-compliant. My recommendation is that teams add a little margin to their design if they can.
Unread 24-03-2013, 11:56
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
1 - The "BUMPER Rules" section of the ROBOT RULES lists everything specific to the bumpers. For the bumper height, R25 clearly states the "BUMPERS must be located entirely within the BUMPER ZONE, which is between 2 and 10 in. from the floor, in reference to the ROBOT standing normally on a flat floor."
2 - Expect them to change every year, and you'll never have an issue at inspection. Read the rules, and figure out your bumper design just like you would your drive train - bumpers are just as important as everything else, and must be constructed legally!
2016: Lake Superior WFFA
Unread 24-03-2013, 12:30
RoeeVulcan's Avatar
FRC #3835 (Vulcan)
it is just that i have an idea for a little more- tactical-bumpers and i wanted to know if they were legal. anyway thanks for the answer. i hope it won't be a one trick pony before first restricts it.
Unread 24-03-2013, 12:37
EricH EricH is online now
Basic word of advice: If it complies with all of the bumper rules, it probably is legal. If it doesn't comply with one or more, it is not legal. If you aren't sure, you're probably best off asking Q&A about it before you get to your first event; that way the inspectors aren't either telling you to change it or asking the GDC and then telling you to change it.
I do remember hearing about some weight-transferring bumpers back before the standard bumper design came out (2006); those were effectively banned by the bumper rules in 2008 (standard bumpers were optional in 2006 and 2007).
Unread 24-03-2013, 12:39
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
The bumper rules are actually quite self-explanatory this year, with the major changes being 3 points:
  1. Hex and Star pool noodles are now allowed
  2. 3/4" thick durable wood is allowed, rather than just plywood, and
  3. Team numbers can be split across bumper gaps
Of course, I have to ask, knowing that I will probably regret it... What the heck is a tactical bumper?
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 24-03-2013, 13:04
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
I mean, given the current rules, it would be legal to use (if you could find it) some 3/4 pieces of ironwood, if you wanted to weigh your robot down for some reason. I even suppose you could weight half your bumpers with a heavy wood and the other half with a light one but I don't know how much within the spirit of bumpers this is.
Unread 24-03-2013, 13:11
Mentor, LRI, MN RPC
Why bother using exotic woods for weight on your bumpers? Just use enough steel in your brackets to get their weight up to 20lbs for the set (if that's what you're looking for). There aren't any rules to using heavy steel blocks with holes thorough them as bumper brackets, so long as you mind the weight limit.
Unread 24-03-2013, 14:53
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
The bumpers are intended for protection and identification. I don't much like when teams start stretching the rules for some tactical advantage.
Pay heed if I am inspecting (or many other inspectors I know) your robot and you are lawyering or stretching the rules you better have a perfect robot in every other respect because you are going to get the most thorough inspection ever.
Unread 24-03-2013, 15:01
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
I don't think this is fair. If teams build their bumpers within the rules, and you don't agree with the rules, why should the team get a more difficult inspection?
It doesn't matter if you like it or not, if they comply with the rules, it is not your position to judge.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 24-03-2013, 15:13
IndySam's Avatar
Originally Posted by Gregor View Post
I don't think this is fair. If team's builds their bumpers within the rules, and you don't agree with the rules, why should the team get a more difficult inspection?
I'm not talking about being within the rules, I'm talking about stretching them to the breaking point. Mounting a 10 pound steel plate to a bumper that has no real practical reason is violating the spirit of the rules.
And as far as your second point, in fact, is is the inspectors job to judge if a team is complying with the rules.
Unread 24-03-2013, 15:18
Gregor's Avatar
Stretching the rules is still complying with the rules. Until it is explicitly illegal to add weight just to add weight (assuming all other bumper rules are met), giving a team a harsher inspection is against the point of inspection. Is the point of inspection not to get all teams on the field, while ensure that they comply with all the rules?
It is the inspector's job to inspect the robot, they inspect the robot for compliance, end of story.
<Since 2011
Unread 24-03-2013, 15:26
Willyspu Willyspu is offline
AKA: Jim
FRC #2144 (Gators)
Willyspu is a jewel in the roughWillyspu is a jewel in the roughWillyspu is a jewel in the roughWillyspu is a jewel in the rough
IMHO:
I just don't like the idea of turning this into a "battle bots" competition. Playing defense is one thing but to be going into a competition with the intent to "take out" opponents is a whole different perspective.
We built our robot very strong knowing that big hits happen, but we also focus on playing the game not destroying the competition.
Additionally, if you are successful in the competition, you may find it difficult finding alliance members in the finals.
What was the phrase? Oh yeah, Gracious Professionalism.
Unread 24-03-2013, 16:02
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Yes, but....when teams don't know some of the rules, they tend not to know others. So while looking at the robot & talking to the team I get the sense that they don't really understand the basics, I take extra time to make sure they haven't missed some of the other things. So, if you don't know how to properly build bumpers (which, despite all the grumbling, are NOT hard) then I wonder if you didn't read the pneumatic rules either. So I'd better take an even harder look at something that could quickly become a safety issue.
Mentor http://www.teamtitanium.org/
Unread 24-03-2013, 16:05
Racer26 Racer26 is offline
I really don't understand why the bumper rules are such an annual sticking point. Anybody with some fabric, pool noodles, plywood, and a staple gun can build legal bumpers in an hour or two.
