Go to Post If chairs really inspired me that much I would be in woodcrafting club and not robotics - CJ_Elliott [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
View Poll Results: What system of motor control for did you use this year?
CAN 16 26.67%
PWM 48 80.00%
Other 0 0%
Multiple Choice Poll. Voters: 60. You may not vote on this poll
Unread 21-03-2013, 10:27
bbuncher12 bbuncher12 is offline
FRC #0540 (Talon 540)
Team Role: Electrical
bbuncher12 is an unknown quantity at this point
CAN vs. PWM
So what did you use this year for motor controllers (i.e. Victors, Jaguars, and/or Talons): CAN, PWM, or another system? We used PWM because we have had a lot of issues with CAN in the past, and also because Talons are WONDERFUL!
Unread 21-03-2013, 11:10
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: CAN vs. PWM
Can is a little finicky, but it has been reliable for us. You just gotta know its limitations. We run our shooter on V rather than V bus. It has been consistent. It can only be done on Can.
Unread 21-03-2013, 21:37
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
PWM works on all of the legal controllers.
CAN only works on the jaguar.
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 24-03-2013, 01:59
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
ablatner is on a distinguished road
Re: CAN vs. PWM
We stay away from CAN because of its many reliability issues. Additionally, Talons are much, much better motor controllers in so many ways than Jaguars, and Talons don't have CAN.
Unread 24-03-2013, 13:10
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Re: CAN vs. PWM
Team 957 used PWM witth Talons for reliability and performance.
If it were not for our rookie programming team, we would not have been afraid to utilize CAN with the new IFI Jaguars if we had any use for the functionality. However, we did not find any use for the extra functionality this year.
Last year's bot utilizes both PWM and CAN, but CAN was not implemented until offseason.
Unread 25-03-2013, 01:38
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Re: CAN vs. PWM
Team 701 made the decision to use Jaguars and CAN when it was first released. We had continuous problems with PWM controls. PWM cables are unreliable, constantly coming loose or falling out completely. PWM cables are not positive locking or keyed.
CAN connections are keyed and positive locking. The connections are reliable and seldom come loose or fall out.
Most of the wiring problems with CAN (and we had many as well) are related to incorrectly manufactured cables. We made our own early on because there were no manufactured cables available. We now have the knowledge and ability to create cables properly.
The additional capability of CAN is hard to pass up. Each Jaguar contains a ARM processor with an enormous amount of functionality. A Jaguar can return the current being used by the motor. This can be used for advanced capabilities like automatic shifting or stall detection. CAN also includes built-in limit switch capability, that can also be queried from the CAN bus. We have used the limit switch interface successfully for several years.
We are sold on CAN and plan to continue using CAN as long as it is available.
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 08-08-2013, 13:01
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: CAN vs. PWM
Our team has only used PWM twice. Once in our rookie year (2008) and once this season. The reason we switched this year was because we have had many problems with jags over the last few years and PWM is easier to work with. When you buy the right parts to make the cables (and make the cables properly) they will not fall out unless the cable is too short or something goes really wrong. CAN does have the advantage of keyed connectors, but it isn't hard to remember that the white wire faces out on a victor.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
