Go to Post There's no problem another CIM motor wouldn't fix! - Tom Bottiglieri [more]
Unread 24-03-2013, 19:11
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
pic: 1538 Wiring 2/4/2013
Unread 24-03-2013, 19:13
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: pic: 1538 Wiring 2/4/2013
Very nice. May I ask how you manage PWM lengths? Are they custom made or do you just hide the extra cable very well?
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 24-03-2013, 19:35
Custom-made. We estimate the lengths with about 1" extra when we're laying out the cables, and then cut to exact length when we terminate them.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 24-03-2013, 20:40
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
Hehe, I like the battery box filled with several hundred dollars worth of modules
"No, you can't use the Kinect to do pelvic thrusts."
Unread 24-03-2013, 22:04
Aidan S.'s Avatar
Aidan S. Aidan S. is offline
2013 World Champions!
FRC #0610 (The Coyotes)
Aidan S. is just really niceAidan S. is just really niceAidan S. is just really niceAidan S. is just really nice
This is very impressive, Great job! How did you guys manage labelling wires?
2013 Galileo Division & World Champions with 1241 and 1477 #TheTheoryOfTexanCoyotes
2012 - ????: Mentor, Team 610 2009 - 2012: Student, Team 610
2013 - ????: Strategy Adviser, Team 1310
Thanks to all the great alliance partners through the years: 67, 188 x4, 191 x2, 488, 469, 578, 842, 862, 1212, 1241, 1305, 1310 x2, 1325, 1334, 1511, 1535, 1477, 1559 x2, 2122, 2168, 3161, 3360, 3396, 3476, 3609, 3756, 4124
Unread 24-03-2013, 22:20
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Good documentation and little changes helps keep labeling unnecessary. Unfortunately we haven't mastered this technique yet
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 24-03-2013, 22:49
Aidan S.'s Avatar
I agree that good documentation is key, but even with that labelling is a necessity. It eliminates the risk of a mistake being made if a component has to be swapped. From experience, I can say that having labels at either end of our wires made my life a whole lot easier at competitions when I was on my team's pit crew.
Unread 24-03-2013, 22:52
Since everything is cut to length and zip-tied down near its relevant component, it's pretty hard to accidentally swap in the wrong cable. We've never had a cable fail.
Team 973 (2016-???)
日本語でOK
Unread 24-03-2013, 23:24
Doesn't mean they won't. On our practice robot we had a PWM short to 12 volts and it caught fire. It killed a victor, the PWM and the sidecar. Had our PWMs not been labeled a 5 minutes swap could have taken a very long time
Edit:Moral of the story: Label everything! Especially the little cables to festos. When you have 6 festos and 2 breakouts things get real hairy real fast if they aren't labeled
Unread 25-03-2013, 00:03
shawnliner shawnliner is offline
FRC #3753 (BulahBots)
shawnliner is an unknown quantity at this point
How do you terminate the PWM's? Is there a special tool for that?
Shawn Liner
Coach
Team 3753
When I learn, I win. If I can win too, that's gravy.
Unread 25-03-2013, 00:05
Yep, we use it and love it.
Team 973 (2016-???)
日本語でOK
Unread 25-03-2013, 00:17
kstl99's Avatar
kstl99 kstl99 is offline
AKA: Kevin
FRC #1922 (Oz-Ram)
kstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond repute
Send a message via AIM to kstl99
Awesome job! The neatness of the wiring is great. Not everyone understands the vaue of it but in the real (working) world where someone is paying for a wiring job that is what they want to see. One sugestion: we have started using wire duct, McMaster Carr P/N 75835K74. It takes up some space but it makes wiring and changing soooo much easier. It eliminates the need for custom PWM cables. I would also highly recommend labeling the wires. Our labels are determined by the line number that they start at on our schematic so they can be easily found there. This is helpful also when you have some components far away from the electrical panel.
One question: How are you isolating the C-Rio? We use Lexan but yous seams to be mounted on aluminum.
Unread 25-03-2013, 00:24
Kara_Walker's Avatar
Kara_Walker Kara_Walker is offline
FRC #4192 (FMHS Robotics)
Team Role: Electrical
Kara_Walker is an unknown quantity at this point
Your wiring is awesome! Even when we spent a good week planning our board and wire routing it still wasn't that neat and we ended up with bundled wires. The metal you used for the board looks like a nice alternative to polycarb and having to drill holes.
Unread 25-03-2013, 01:21
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
We use 1/16" rubber adhesive backed rubber sheet. It's underneath the cRIO.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 25-03-2013, 01:51
kiettyyyy's Avatar
I'm not a huge fan of labeling where it isn't necessary, especially in our application.
As Connor mentioned, cables are neatly ziptied and cut to length.
At the San Diego Regional, we happened to have a metal shaving short out our digital side car, meriting a complete replacement. The digital sidecar was replaced and tested in under 2 minutes. Not many teams can replace a fully loaded DSC in that time even if it were labeled.
It's just personal preference.
-Kiet Chau
www.team1538.com
