Go to Post An amazing manipulator system is worthless without being able to drive reliably. - RoboChair [more]
Unread 24-03-2013, 20:34
Dan Oelke Dan Oelke is offline
FTC #5926 (The Things)
FRC #3023 (Stark Industries)
Dan Oelke is an unknown quantity at this point
DC-DC voltage converter for flashlight
We got a flashlight to use as a photon canon. And are having issues driving it.
The flashlight we are using is "LED Lenser P7"
http://www.amazon.com/gp/product/B001AT1F6S
It uses 4 AAA batteries so it needs 6V into it. We got a DC-DC converter specifically this one: http://www.amazon.com/gp/product/B008BHAOQO
And wired it up on the bench and everything seemed fine when we plugged it into a battery.
Then we wired it to a relay on the bot - so that the relay provided power to the DC-DC converter which was then wired to the flashlight. After that - it wouldn't work. Before bagging we found that the DC-DC converter output was only 1.6V instead of the 6V it had been adjusted to. Playing with the adjustement screw did not seem to give any different output.
So - any ideas on what we might have done wrong? I think the polarity was always right for the input to the DC-DC converter. Would have reversing it on accident blown something you think?
Any other ideas? Is there a better/more robust DC-DC converter we should be using?
Our regional starts in a few days and we would like to be ready to swap out the offending part for a quick recovery.
Thanks!
Dan
