Go to Post For me Gracious Professionalism is about helping other teams make their ideas work. We do everything we can to help other teams program, or lend them parts from our pit. On the field we play to win. - Alpha Beta [more]
Unread 24-03-2013, 20:06
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Thumbs up Share your Java Utilities and Object Classes
So I am sure just about every team has written a class for something that isn't in the library, or some other utility to aid in code development/testing. In the spirit of Gracious Professionalism and Open Source, I would love to have us share our creations.
For my contributions:
XboxController Class that is compatible with the CommandBase OI Button and Scheduler system. It also assists by using subclasses for the buttons and axises to alleviate memorizing the button/axis numbers.
XboxController
Threaded RaspberryPi Socket Connection. This is a little more specifically written to our uses, but it is likely useful for any co-processor using a TCP Socket Connection in a separate thread to prevent the robot from crashing if the thread crashes.
ThreadedPi
ThreadedberryPi (subsystem)
Then I have python code for a RaspberryPi for processing images and using a TCP Socket Server. This was not written by me, but we used it on our competition robot which has perfect killer accuracy. It calculated Distance(in millifeet) and pixels from center. The distance wasn't quite accurate, but was consistently inaccurate(useful if you recorded target points).
PyGoalFinder
I hope these helps someone. And thanks for sharing if you do so!
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 24-03-2013, 21:36
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: Share your Java Utilities and Object Classes
Here is our current code, we have quite a few of these things,
  • util.CoupledTalons is a class we have to run two talons in sync with eachother, it also ramps the power on them.
  • calibrations.* are classes that let us calibrate sensors and get usable numbers from them, we have one for an encoder with a limit switch at one end of it's travel, and one for a pot with one on each end.
  • limitSwitches.* are classes that make using limit switches easier. There is NCLimitSwitch which is a wrapper for the normal digital input class that inverts the input so we can't forget to do it. LimitSwitchSystem is an interface for a class that helps with using limit switches as bounds, SingleLimitSwitchSystem is one that just has one limit switch, DualLimitSwitchSystem is for two. They both return values of the LimitSwitchState enumeration, which has values for when the switches are pressed and for when they aren't.
  • controllers.* are classes that generalize motor control using the calibrations and limit switch systems. There is SimpleController which works exactly like a normal motor controller, except for the fact that it uses the limit switch states to limit the motion. StringPotPidController and EncoderPIDController add PID on top of the simple controller.
The code isn't commented very thoroughly yet as the code is still changing and we haven't had a lot of time to comment it, so don't hesitate to PM me with questions.
Unread 24-03-2013, 21:45
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
https://github.com/team1306/Badgerbo...badgerbots/lib
Unread 25-03-2013, 18:39
shindigo shindigo is offline
AKA: Mike Parker
FRC #0102
shindigo is an unknown quantity at this point
Thanks for the thread, thanks for the posts. Always good to read other people's code. I do not have much to contribute, but we have found this library useful for Math functions that Java ME does not provide: http://javolution.org.
Does anyone know a simple lib for formatting floating-point numbers since printf is not available?
Unread 27-03-2013, 15:30
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
gixxy's is probably superior, but here is a link to a mapping file we use for XBox gamepads (We just use the Joystick class and these mapping values).
If you just want to fix to a specific number of decimal points x, you could make a simple helper class/method that multiplies it by 10^x and casts to an integer, then divides it back down to a float... but you probably already thought of that
Unread 31-03-2013, 20:33
armgeek's Avatar
armgeek armgeek is offline
Raspberry Pi Enthusiast
AKA: Tyler Pawlaczyk
FRC #0340 (Greater Rochester Robotics)
armgeek is an unknown quantity at this point
ThreadedPi
We bit-banged an SPI-interface for the Raspberry Pi, but assuming nettables doesn't interrupt your solution, yours looks much better.
Our team also wrote code for a Raspberry Pi that we intended to use on the robot (we couldn't due to weight limitations), and we used C++ and OpenCV to create an image processing program. Our team intends on publishing a Raspberry Pi image designed for FIRST this summer. Thanks for publishing this.
I enjoy ARM processors.
Looking to earn rewards for working on Open-Source projects that help FIRST? You may be interested in the Summer of FIRST 2013 project. More info: 2013.summeroffirst.org
Also, visit my (sparse) blog: rainingbitsandbytes.blogspot.com
Unread 01-04-2013, 02:15
gixxy's Avatar
A TCP Socket Connection is basically Serial over a Network. While I'm not going to say Net Tables CAN'T cause a problem, I would find it very peculiar if it did.
We used the RPi (with said posted code) at competition this year and besides issues with autonomous (if it wasn't fully booted in time) it worked perfectly!
Unread 28-08-2013, 19:13
Ipiano's Avatar
Ipiano Ipiano is offline
AKA: Andrew Stelter
FRC #3018 (Nordic Storm)
Ipiano is an unknown quantity at this point
I'm not sure how relevant this is, since the topic seems kind of old, but I wrote this up last season and think it was extremely useful. It's a set of classes that can be extended to automatically set up a way to edit autonomous code on the fly so you don't have to re-download and restart the CRio just to change a simple variable. This makes having multiple autonomous sequences easy to manage, and brings extreme flexibility to that section of the game. The only downside that it only works for teams using the command base, and it is a little tricky to set up.
https://github.com/Ipiano/Parsable_Autonomous
________
Genius is one percent inspiration and ninety-nine percent perspiration.
--Thomas A. Edison
