Thread Tools |
Rating:
Display Modes |
Re: Question about 1114's Climb
First of all that is one awesome robot. But it does seem to violate G23-1A since the 54 cylinder is relative to the robot when contacting the pyramid. (At least the way I read the rule.) Obviously the refs & inspectors at Waterloo have a different interpretation & they are the ones with a vote.
You can easily see what is happening at the end of this video
http://www.youtube.com/watch?v=qQm__Yyf7Oo&safe=active |
The robot doesn't even leave starting configuration until its on the pyramid, and then it extends in the same direction as their robot's longest dimension, which for the purposes of the cylinder can be pointed "up". This is one of the most compliant climbers in FIRST, probably even meeting the old "floor relative" 54" cylinder in addition to the relatively new "whatever orientation you want" 54" cylinder.
#7
Blog post are not the rules (As Frank (not me the other Frank)) has said.
The rule says Quote:
#8
- Sunny G. |
#9
An answer from Q&A about the order of precedence. By definition the Referees are the final deciders at any event. Really as it should be. Q&A is last on the list.
This climber is definitely compliant with the 54" cylinder rule with both the old and new interpretation.
In addition, it does not touch the vertical pole in zone 2. When you see it up close it is very obvious. This climb is ridiculous when you see it up close. Very fluent, very stable ... just plain awesome. FrankJ, I get your point, but there is no ambiguity here (as implied from the order of precedence Q&A). Frank (FRC Director) stated in a blog post the intent of the rule change. In addition, the Q&A question and answer quote above made it perfectly clear that an 84" high 54" diameter right circular cylinder can be put in any orientation around your robot while it is climbing. The 1114 robot is within both a vertical cylinder and the one rotated in their favor (along the vertical pole). Last edited by Paul Copioli : 25-03-2013 at 20:16. |
