Go to Post In fact, one of our volunteers just found out about the entire FIRST program two weeks ago and had so much fun on Thursday that he came back on Friday to help us again! - KathieK [more]
Unread 03-22-2013, 09:00 PM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Custom Pixel-By-Pixel Vision Processing
We've been doing vision processing via a HTML server, but the problem is the drivers don't like to use all of the programs including RoboRealm so we want to do it in Java. ColorImage does not support per-RGB scanning but Squawk doesnt support BufferedImage. any help?
Unread 03-23-2013, 01:51 PM
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Custom Pixel-By-Pixel Vision Processing
Last year one of our students wrote image processing code in Java.
We used the command based robot template. The camera Code resides within a subsystem.
The code is available here for reference:
https://gist.github.com/jcorcoran/5228621
Hopefully that helps get you moving in the right direction.
Something to watch out for is performance. The frame rate can get pretty low for image processing running cRIO side. You may want to look at performing your vision processing using openCV through the smartdashboard. Vision processing code would run on on your driver station laptop in this case. There are plenty of good resources on driverstation side image processing code.
http://www.chiefdelphi.com/forums/sh...ght=341+vision
https://code.google.com/p/frc2012-te...i/VisionCoding
http://team2168.org
Unread 03-25-2013, 03:55 PM
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
No... our current camera image code is fine :\ manufacturer grade quality at that, its just that the drive team doesn't like using custom dashboards so we cant do offboard processing and we need to do it onboard, but dont want to use the sloppy nivision libs and do custom pbp.
Unread 03-28-2013, 08:11 PM
I'm curious what you find sloppy about nivision?
Greg McKaskle
Unread 01-02-2017, 11:38 PM
AMendenhall AMendenhall is offline
FRC #3925
AMendenhall is an unknown quantity at this point
I don't find the NIVision libs sloppy; just unusable for any complex operations. So far as I know and have experimented, there is no way to interact with NIVision.Image type images except through NIVision methods. Also, there's no way to create NIVision.Image type images other than with a webcam. Not only does this drawback leave many (including me) with no option other than using external libs, it makes CameraServer, which is compadible only with NIVision.Image images, useless. Please, if I'm wrong, correct me. I would like to use the utilities provided by default if I can.
Unread 01-03-2017, 09:51 AM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
1. We used nivision for some pretty complex stuff last year.
2. Have you seen imaqCreateImage? Or the (somewhat useful) documentation in Program Files\National Instruments\Vision\Help?
3. It's really not that hard to implement CameraServer yourself. It's literally just the bytes 1 0 0 0 followed by a 32 bit integer n, followed by n bytes of a jpeg image. Over and over on a tcp stream
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
