Go to Post PS: When/if it gets to be too easy to build a machine that can accomplish a recent/typical FRC game, then I suspect it will be time for someone to unveil a harder game. - gblake [more]
Unread 25-03-2013, 11:23
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
pic: High Goal Worse for the Wear
Unread 25-03-2013, 11:25
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Re: pic: High Goal Worse for the Wear
It's funny how the damage is heaviest around the top of the goal, while dead center is nearly clear of scrapes and marks.
Seeing this same goal at the end of the season would be interesting.
Unread 25-03-2013, 16:42
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
The top of the rear of the goal is probably scarred due to the angle of the shooters?
The middle is probably protected by the chains?
Then, why is the top so scarred if the impact is closer to the chain anchors.
Hmmm, IDK, maybe due to the velocity of the angled shots?
Unread 25-03-2013, 17:00
Chris is me's Avatar
AKA: Pinecone
I think the top hits are all coming from low (sub-30") shooters, and the bottom hits are coming from high (nearly 60") pyramid shots or full court shots. Low shots generally enter the goal at an angle, while higher shots are more level.
There is definitely way more wear on the top because it is far easier to get a repeatable shot if the frisbee enters the goal on its way "up" the flight path rather than down.
