Go to Post I think your robot is lacking in non-threatening, huggable design. - Kevin Sevcik [more]
Go Back   Chief Delphi > Competition > Regional Competitions
  #106   Spotlight this post!
Unread 24-03-2013, 08:17
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
Re: 30 Point Climb Club
Add 88, TJ Squared, at Boston.
30 Point Climb, with a dump, twice I think.
Once in the Final match. The crowd went wild.
  #107   Spotlight this post!
Unread 24-03-2013, 11:42
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
If anybody you wants to see a good climber match, watch qual 55 from Wisconsin. I don't think the video is up anywhere yet, but I'm sure it will be.
There were 4 outside corner climbing robots. 3 on blue. 1 on red. 4143 (blue) climbed and dumped for 50. 2481 (blue) tried to slow down 1714 (red) because their climb was slower. Both ended up climbing for 30. 1259 (blue) didn't get their climber working until their next qualification match. Or maybe they we were just scared to get on the pyramid . Blue scored 127 and didn't shoot a single teleop disc (except for the 4 pyramid dumps). Match ended with 2 bots at the top of blue and 1 on the top of red.
A side note to climbing teams. Make sure the refs give you the points. There was once where I think they forgot to count the pyramid discs. I don't think it affected anything. When you have to use the belay system on 2 or 3 bots, the field crew has a lot to do.
It's really hard to verify the pyramid discs get counted because differences between the hand count and the scales can shadow the addition of pyramid discs.
I know a least once where they forgot to give climb points. In quarters 2 match 2, blue climbed for 50 points but final match score showed 20 climb points. Our driver went to the question box. The ref acknowledged the mistake, but didn't change anything because the outcome didn't change.
Wisconsin had a ton of great climbers and the crowd loved it. The only thing louder than the crowd cheering a climber to the top, was the groan of a 20 point dismount.
  #108   Spotlight this post!
Unread 24-03-2013, 12:00
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
Originally Posted by rkbot View Post
The pyramids atleast at gte were relativlely flimsy, on one of our climbs the pyramid separated and one our hooks disengaged and we almost fell.
Edit: I added a picture of one of our 30 point climbs at gte
Familiar problem...
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
  #109   Spotlight this post!
Unread 24-03-2013, 13:18
JeremyF JeremyF is offline
FRC #0088 (TJ(Squared))
JeremyF is an unknown quantity at this point
As correctly posted above, TJ2 was able to successfully climb the pyramid and dump for 50 points numerous times throughout the Boston Regional. Even though during Saturday's qualification matches we had climbing trouble, we were gratefully picked by the excellent alliance of 846 and 3137. Our alliance eventually reached the finals to face the unstoppable force of 125, 126 and 1511, where we finally were able to reach the top of the pyramid for the 50 point climb and dump for the first time in the elimination matches. Although we lost the match, we were happy to finally complete our strategy at the most perfect and critical time possible. The recorded live stream of the very exciting finals can be seen here:
http://www.ustream.tv/recorded/30284111
Provided by Team 125.
(The 30 point climb and dump I mentioned begins at about 19:00)
Great job to all teams that attended. It was, once again, an awesome Boston Regional!
  #110   Spotlight this post!
Unread 24-03-2013, 15:07
DsRandhawa3244 DsRandhawa3244 is offline
AKA: Dilpreet Randhawa
FRC #1259 (Paradigm Shift)
DsRandhawa3244 is an unknown quantity at this point
1259 hit the 30 pt climb with the 20 pt dump! We didn't get it working 100% consistently in time for our match with 4143 and 2481, which was disappointing, but we hit it in most of our matches after that with the only exceptions being instances where we were defended and left with no time.
  #111   Spotlight this post!
Unread 24-03-2013, 20:37
Here is a video of 4143 climbing to the top in 20 seconds. http://www.youtube.com/watch?v=H9aeUJRZ8zk
I didn't count the time it takes us to line up. We didn't dump for 20 in this match because the plan was to clog up their loading zone. 2826's feeder jammed in this match so it wasn't as competitive as we were expecting.
  #112   Spotlight this post!
Unread 24-03-2013, 21:29
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
My brother Mr. Forbes filmed a climb by team 842 in the semifinals of the Phoenix Regional.
It's the most wonderful thing - it looks like a trapeze artist at work.
http://www.youtube.com/watch?v=8mbC_suZXs0
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
  #113   Spotlight this post!
Unread 24-03-2013, 23:21
Gamepad3496's Avatar
Gamepad3496 Gamepad3496 is offline
AKA: Corey
FRC #3496 (The Robotech Collection)
Team Role: Driver
Gamepad3496 is an unknown quantity at this point
Hi guys! I've witnessed a few climbers at the Queen City Regional 2013 matches. I saw quite a few climb to the 30 mark. Our robot also climbed to 30 and dumped 4 Frisbees into the pyramid goal, we made it to the quarterfinals and climbed to 30 both of our rounds successfully. It's really awesome to see all of the teams who've managed to go to all the way to 30!
  #114   Spotlight this post!
Unread 25-03-2013, 12:19
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
As has already been mentioned TJ^2 (FRC 88) got several 30 pt climbs at Boston and dumped Frisbees at least 3 times including in the Finals.
We might also be the only second team so far to dump 4 Frisbees in the top goal but not score any climb points when we fell off the top of the pyramid.
Last edited by MikeE : 25-03-2013 at 15:34. Reason: I watched 1023 video several times but focused on the fall, not the pyramid score!
  #115   Spotlight this post!
Unread 25-03-2013, 12:34
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
We might also be the only team so far to dump 4 Frisbees in the top goal but not score any climb points when we fell off the top of the pyramid.
1023 made that famous a few weeks ago
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
  #116   Spotlight this post!
Unread 25-03-2013, 12:49
Trez's Avatar
Trez Trez is offline
FRC #3606
Trez is an unknown quantity at this point
Team 3606 BearMetal climed to 30 points 9 times during qualifacation matches and two more times during elinimation during the Bayou Regionals. We would have climed to 30 points 10 times during qualifacations but we climbed to 10 and let 2992 climb becasue they could dump in the five point goal.
Prototype, Prototype, Prototype
  #117   Spotlight this post!
Unread 25-03-2013, 13:24
Originally Posted by RyanShoff View Post
I don't think the video is up anywhere yet.
Here are the two best climber vs climber matches I remember from Wisconsin.
http://youtu.be/qlFGh6jrP3w Qual 55
http://youtu.be/4Ea7oxRi21o Qual 72
  #118   Spotlight this post!
Unread 25-03-2013, 15:35
MikeE's Avatar
no team (Volunteer)
Very true. Fixed above.
  #119   Spotlight this post!
Unread 25-03-2013, 20:03
ThunderousPrime's Avatar
ThunderousPrime ThunderousPrime is offline
All Drive. No Drama.
AKA: Nick Brown
FRC #1511 (Rolling Thunder)
ThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to behold
I am happy to say that my team team 1511 Rolling Thunder joined the 30pt hang club during the Boston Regional. We were able to achieve the climb during various matches including during the quarterfinals (I believe this is correct but am not sure if it was Quarter Match 1 or 2) and Quals 52, 63, 74 and 83. Attached is a picture of a 30pt hang and a picture of the robot, for the climb picture is zoomed out. (I cannot remember what match the hang in the picture was from.)
ID:	14440  Click image for larger version
  #120   Spotlight this post!
Unread 25-03-2013, 20:41
caseybarisax14's Avatar
caseybarisax14 caseybarisax14 is offline
AKA: Casey
FRC #0587 (The Hedgehogs)
caseybarisax14 is an unknown quantity at this point
Team 587 climb to the third level at North Carolina Regional two weeks ago and dumped two times
