Go to Post And Dave, although I know you have connections, please don't slow the earth's rotation to get more time on the caption contest. ;) - Billfred [more]
Unread 27-01-2003, 19:31
adamoneDB04 adamoneDB04 is offline
#1018 (RoboDevils)
adamoneDB04 is an unknown quantity at this point
pneumatics
what do you think the smallest area that should be allowed to fit the pneumatics on a robot?
Unread 28-01-2003, 11:59
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: pneumatics
Actually it is more a question of volume. The answer is just a little bit more volume than the parts you are using. Remember, not all parts need to be mounted flat on your base. I don't remember if the compressor has to be mounted upright or not. You should check the manual on that. But certainly the cylinders do not care about orientation.
If needed, you can fight with the electrical team for volume. Their harware WILL run in any orientation. We have routinely installed electronics upside down and sideways to free up real estate for other sub systems that had to be upright.
I could give a batter answer with more details, right now I'm trying to answer the question I think you're really asking. ie "how do I get this all to fit?" It depends on the number and size of cylinders you are using, whether you can perform your functions with stored air or need the compressor on board, what valves you are using and many other factors.
You can always PM me with details if you think it might help
Christopher H Husmann, PE
"Who is John Galt?"
oil for for Pneumatics nragod Pneumatics 8 03-02-2003 22:30
Programming PBASIC for pneumatics archiver 2001 2 23-06-2002 23:58
PNEUMATICS PLEASE HELP archiver 2000 1 23-06-2002 23:06
pneumatics tank archiver 2000 2 23-06-2002 22:43
Filling the pneumatics tank archiver 2000 4 23-06-2002 22:43
