Re: FRC Blogged - Doing the Right Thing
and there was certainly enough 'new' in 2011 to talk about aside from something so rare as a tied elimination match.I can't deny the efficiency of settling an elimination series this way, but really... in all the FRC, FTC and VRC events that I've attended that have gone "over time", I don't think the "tie breaker match" has ever been the main cause. No doubt it happened at IRI once, but it seems weird that an anomaly at an off-season event should impact 'real' FRC events. Anyway, thanks for the update... and I should really be focusing on the GP shown last weekend, as described in the blog post... but I will be cheerfully grumpy for the next while about how "it was better in the old days when we settled ties the honorable way!" Jason |
There is a fairness aspect to it as well. Once again going to the WPI quarterfinals, the other two alliances both had essentially an hour+ of downtime waiting for their opponents to be decided. Meanwhile, the #2 seed had to go straight into semis after a grueling 3 extra matches, the last of which with only the standard 6 minute break in between. Their first semifinal was a tie as well, leading to another two back-to-back matches before they made it through to finals. 1735's drive motors overheated in the finals after having played 9 nearly consecutive matches. When all was said and done, 1735 and their partners 2370 and 663 played 11 matches in eliminations, only one less than they did through qualifiers. This was an extreme example, but it and other similar episodes around the country did prompt the tiebreaker rules to come into play for the sake of the teams, as well as the audience and volunteers. I guarantee that alliance would have performed significantly better in the finals had their robot and driveteam not run through the equivalent of a second regional in just 3 hours. While the games since have not had the propensity for ties that 2010 did, it has come up a few times (including Galileo Semifinals in 2011). I agree with you that it's much more exciting (in general) to play out ties...but after having been through WPI 2010, I understand the necessity of having tiebreakers in place. Last edited by Nuttyman54 : 26-03-2013 at 23:51. |
In 2011, ties occurred in ~4% of qualification matches in 2012, ties occurred in ~3% of qualification matches So far in 2013, ties have occurred in ~1% of qualification matches |
I'll admit that five tiebreakers is a bit excessive, and could be seen as being responsible for delaying the completion of the event, however there were a total of 22 elimination matches played, including the tiebreakers. An event should be prepared for 21 elimination matches, assuming each of the seven series goes to three matches. So technically, even with all those extra tiebreakers, the event would have gone one match... six minutes... beyond what would be achieved in a "longest case" scenario using the current rules. I submit that based on the 2010 elimination rounds that tiebreakers are an anomaly and are rarely (if ever) the root cause for an event running beyond time limits. I'll admit that there needs to be something in the rules to allow events to finish at a reasonable time, however I'll also submit that saving six minutes is hardly worth giving up the "tiebreaker" match. And while I'm happy to admit that this totally falls into the category of "first world problems", I'll argue that we should settle ties on the field... in the finals at the very least! Jason P.S. at the other two events that had tiebreakers, they both ocurred in the finals... the perfect time! Oh, yeah... full disclosure... I'm a bit of a hockey fan, and playoff games aren't considered "epic" until at least the third overtime period, so there might be a bit of a pre-existing bias. Last edited by dtengineering : 27-03-2013 at 01:09. |
If it were you in those matches, you would want the people in the stands to stay and cheer. Gracious Professionalism means understanding that those teams playing on that field are creating a memory that they'll never lose, putting yourself in their position, and cheering like crazy. FIRST is about inspiration, and winning through penalties is hardly inspirational. Last edited by Tom Line : 27-03-2013 at 07:18. |
#7
I hardly think a tie-breaking system that is clearly outlined in the rules destroys the inspirational value of a win. |
#8
So all this talk of tiebreakers has me thinking:
Suppose for a minute that Central WA was being run under the pre-2011 tiebreaking system of infinite replays until a winner is found. Based on what I've heard of the incident, it took a few minutes to discover the offending disc, likely enough time to have started the tiebreaker match. What happens then? My guess is that 2pt disc gets counted in auto of F4, and now you have two matches whose outcomes have been affected by a sloppy count. Do they still go back and award the red alliance based on their legitimate win of F3? |
#9
Personally I am pro-replay/tie-breaker but there's a caveat. I am pro-replay because if the issue is possibly the result of unusual man made intentional interference it thwarts awarding the match to the person causing the interference.
On the other hand replaying a match as other's have noted carries with it the same risk of human error and the circumstances for each robot may differ. There is no reason to suspect that all the robots for any given match will be operational at the same levels from match to match. This can result in a match with a different mix of robots or different factors that directly impact the score. Again, to me, winning the matches has an element of randomness to it and obviously strategy can impact the score as well as the robot designs and build qualities. I think making it to the competition at all with something resembling a finished robot is a major achievement for anyone that does it. Last edited by techhelpbb : 27-03-2013 at 11:56. |
#10
