Go to Post Side effect include: Hearing loss, splinters, blisters, extreme sprit, uncontrollable urges to scream "GO MOE", and bright green fashion sense - The Lucas [more]
Unread 27-03-2013, 00:36
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
3" dia CIM motor
i am considering using one of the old 3" dia CIM motors for a budget electric scooter project but i can't find any specs on them.
i'm looking for info such as k/v, torque, amp draw, rpm, ect
does anyone have experience running them at higher voltages like around 24-36v? if so, how long do they last at higher voltages and is it a good idea to run them that high?
and finally, HOW DO YOU MOUNT THEM??????
seriously, i don't get it. there's the one mounting hole on the front and that's it.
only thing i can think of is to clamp it
My Instructables
Unread 27-03-2013, 01:02
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: 3" dia CIM motor
If you aren't seeing the other mounting option, odds are someone on the team you got it from has cut it off already. (The motors are supposed to have a stud on the face plate, to which a belt tensioner attaches. You could remove the tensioner and retain the stud.) Clamping is a pretty good option, though unfortunately, I don't think these motors had an alignment boss around the shaft.
Basic specifications are here (on page 8).
(For those who don't know, the mini-bike CIM was used on a Fisher-Price toy motorcycle, and provided in the 2006 and 2007 kits as FP801-005.)
Unread 27-03-2013, 01:06
xSAWxBLADEx's Avatar
xSAWxBLADEx xSAWxBLADEx is offline
DaBears til 13 turned Free Agent 14
AKA: Michael Hawley
no team (Free Agent)
Team Role: Scout
xSAWxBLADEx will become famous soon enoughxSAWxBLADEx will become famous soon enough
Send a message via MSN to xSAWxBLADEx
Are you talking about the mini-bike motors?
FP801-005 Mini-bike motor
http://www2.usfirst.org/2007comp/oth...0Practices.pdf
2006-Palmetto Regional Champions with 11 and 1251 (MORT, TIGERS, BEARS, O MY!)
2007-Pittsburgh Regional Champions with 123 and 337 / Detroit Regional Champions with 123 and 903
2009-Traverse City District Competition Champions with 85 and 2645 / Traverse City District Competition Chairman's Award / Michigan State Championship Finalists with 1918 and 904 / Championship Finalist with 217 and 68
2013-Grand Blanc District Competition Champions with 33 and 1718
Unread 27-03-2013, 12:27
As I recall, the front face was somewhat teardrop-shaped, giving two flat sides that could be used to keep it from rotating. I know 330 clamped theirs by bending allthread into a U shape of the proper diameter and setting them on a light-duty platform, then using the custom Ubolts through it, back in 2006, and as far as I know, it's still there. (Admittedly, this was a shooter motor--but we never did have any issues with the shooter not working once we got it working.)
Unread 27-03-2013, 15:37
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
I used these motors on a project a few years ago. The way that I mounted them was there are 2 bolts that hold the motor together one when stock will stick out ~1.5" you can replace the 2nd one with a longer one so that you have 2 bolts to mount from. The thread is an M6 but I dont recall what the pitch is but I can look it up if needed. I also cut the profile of the face of the motor into the plate that it mounted to. Below is a link to some pictures showing what the profile was. I can send you the CAD model of the plate if you would like.
https://picasaweb.google.com/1147137...eat=directlink
