Go to Post Not gonna lie, I wanna marry the person over at #254 who does their wiring... I have admired it for years. :) - Lightfoot26 [more]
  #61   Spotlight this post!
Unread 26-03-2013, 15:15
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Re: Climbing and dumping not winning?
Originally Posted by RyanShoff View Post
2481 Roboteers lost because they fell over very early in their last match. Had that alliance got the 50 points from that robot, they would have won. It was their first regional and I'm sure they won't be that tippy at Crossroads.
Additionally, they would have won if 269's ten point hanger hadn't broke in the first finals match. So, 2481 got extremely close to winning a regional as a climber-dumper.
I think the key for the climber-dumpers is they need to be able to do something else than just get those 50 points. Ideally, they can get 18 points in autonomous and then do a cycle or play defense before starting the climb. I'm not sure a pure climber-dumper can be a foundation of a winning alliance.
  #62   Spotlight this post!
Unread 26-03-2013, 15:33
Chris is me's Avatar
AKA: Pinecone
I think that in theory, a very fast (as in can go from at the feeder station at the 30 second mark to points) could be an excellent component of a winning alliance this year, but "pure dumpers" tend to just take far too long to be useful defensively.
At BAE, 3467 had basically a 30 second climb but with no dump. They could slow each team down 1 cycle and then climb for 30, making an easy net contribution of 54 (+30 / -24) to the alliance. Unfortunately, I think a lot of teams designed pure hangers with defense as an afterthought.
  #63   Spotlight this post!
Unread 26-03-2013, 15:46
Racer26 Racer26 is offline
So.... 1114?
  #64   Spotlight this post!
Unread 26-03-2013, 16:45
In Los Angeles, 3309 parlayed climbing into being picked first. When they broke out their climb-and-dump for the first time (all 50 points of it!) in the late QFs or their first SF match, they put a HUGE target on their backs. Regional finalist 981 proceeded to play very aggressive defense during the next semi, stopping them cold (981's alliance won the match, despite racking up 3 Technical Fouls from that defense). Apparently, something went wrong with 3309's climber during the third match--despite a lack of defense (though the threat was there), they didn't climb.
4210, the other triple-bot (though no dump) at the event, was knocked out by a barrage of shots from the #6 seed's three shooters into the goals.
  #65   Spotlight this post!
Unread 26-03-2013, 17:08
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
The 68 point strategy is great (18 auto + 50 dump). The trouble is that it's quite difficult to pull off. We tried to build that robot, but we decided to abandon our 30 point climber in favor of a 10 point climber for our next regional. Our climber was fairly complicated and took a long time to put together, so that led to some issues.
The thing that made the climber design extra hard was having a shooter in the way of everything. Our shooter is curved with an 8" wheel, and that takes up a ton of space, especially with the smaller frame perimeter. We were very close to the limit on all of our starting configuration space constraints, and that made it hard to create something with some margin for error.
We worked a ton on that climber, and I think we came pretty close to getting it working. But I don't think it would have been fast enough to justify its existence given how fast it's possible to score a volley of four discs. Our design would have taken more than a minute to climb and dump - at that rate, it's possible to make 12 point disc runs and have nearly as much point scoring potential. 3 pointers are way less risky, both in terms of robot damage and the risk of losing 80% of the points you were trying to score if you aren't fast enough. The fast scoring surprised us about this game - we thought it would be slower to get back and forth from the feeder and score discs, and we thought defending robots would be more successful at slowing down shooting robots than they are in practice.
So here's why I think climbing and dumping isn't winning:
1) A frisbee shooter with a 10 point hanger can outscore a pure 50 point dumper, and the former is quite a bit easier to build.
2) It's really hard to build a 50 point dumper that can also shoot 3 point shots, whereas a human loading 10 point hanger + shooter is within the reach of most teams.
3) A 50 point dumper is all or nothing (or close to it). A shooting robot can experience minor issues or defense and still score a significant fraction of its expected points.
  #66   Spotlight this post!
Unread 26-03-2013, 17:11
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Yep, it was our camera mount of all things - it was bent such that the drivers had no idea if they were lined up to climb (we'd been battling pyramid alignment issues all weekend, finally gotten them solved, only to have this happen, naturally more fixes will happen for LV).
Our team agreed early on that a 50 point climb and dump alone wouldn't cut it - an 18 point auto and telop shooting are needed to balance things out and prevent the "one-trick pony" problem. We really only had everything working together at the very end of LA, it certainly takes time.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
  #67   Spotlight this post!
Unread 26-03-2013, 23:40
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Alignment, alignment, alignment that is the bane of existence of all climbers. I seen so many corner climbers including my own being slightly off and falling off. Not only you have to a have a fast climb but you need to pull yourself into alignment quickly.
That is why I really like 1114 system, they seem to have a wider window for alignment allowing for a quick alignment when they climb for the ten point mark.
No point in climbing quickly if it take you 30 seconds to line up. Your just going to be too slow. If our robot can't align quickly, we certainly won't be in the running to win Las Vegas. Though the odds of wining in LV are more related to if 987 is on your alliance or not.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
  #68   Spotlight this post!
Unread 27-03-2013, 00:56
ttldomination's Avatar
Sunny
Originally Posted by Racer26 View Post
So.... 1114?
I don't think anyone would define 1114 as a 'pure dumper'.
- Sunny G.
1648: 2013-2014
5283: 2015
  #69   Spotlight this post!
Unread 27-03-2013, 01:31
NXTGeek's Avatar
NXTGeek NXTGeek is offline
AKA: Malachi
NXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to behold
A robot with a 7 disk auto and a 10pt hang can beat a fifty point climber by basically just sitting there during teleop. With a couple rounds during teleop, then it's more like 100 points, let alone 50.
2013 -Team 3476
Champion (Fall Classic)
Champion (Battle at the Border)
Finalist (Indiana Robotics Invitational)
Newton Division CHAMPIONS (Worlds)
Wild Card as Finalist Alliance Captain (Inland Empire -> Worlds)
Innovation in Control Award (Inland Empire)
Industrial Design Award (San Diego)
Semifinalist (San Diego)
2012 -Team 3476
Champion (San Diego -> Worlds)
Excellence in Engineering Award (San Diego)
2011 -Team 1425
Engineering Inspiration Award (Portland Autodesk -> Worlds)
Finalist (Portland Autodesk)
WFFA (Tim BD, Portland Autodesk)
Finalist (Seattle Olympic)
Entrepreneurship Award (Seattle Olympic)
  #70   Spotlight this post!
Unread 27-03-2013, 01:38
dcarr's Avatar
#HoldStrong
AKA: David Carr
A robot that scores more points definitely beats a robot that scores less points.
How you score them is up to you
I think the important takeaway is that performing only one aspect of the game can be successful but will not guarantee dominance.
Team 3309
Team3309.org
  #71   Spotlight this post!
Unread 27-03-2013, 01:53
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
I'm not sure I grant the assertion here. A robot that scores 50 points every single match match is easily in the top 100 of all robots. A robot that scores 68 should be in the conversation for top 10. Any robot that consistently scores 68 points per match would win, a lot. Perhaps the OP assumes climb&dump isn't winning because there's inconsistency in the climbing and the dumping.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
  #72   Spotlight this post!
Unread 27-03-2013, 02:02
dcarr's Avatar
#HoldStrong
AKA: David Carr
Certainly, there are inconsistencies with any type of scoring - defense, mechanical defects, etc. What you can accomplish in two minutes on an empty practice field has little bearing on what occurs in a real match. With climbing being somewhat more difficult, more can go wrong.
Team 3309
Team3309.org
  #73   Spotlight this post!
Unread 27-03-2013, 06:56
GearsOfFury's Avatar
GearsOfFury GearsOfFury is offline
Former guy that does stuff
AKA: Mark Anderson
GearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to behold
I haven't seen ANY other consistently strong Climb+Dumpers. A Climb+Dumper with no auto, and 100% consistency should have an OPR of exactly 50. That would be a top contender at nearly every regional.
A fairly trivial 4 to 6 point auto could be added with minimal effort, and with 100% consistency, that would bring OPR in line with the likes of 610. Not as strong as 1114, 2056, 987, or 1986, but certainly strong enough to win weaker regionals, or be a top pick at a regional with only 1 powerhouse.
As MrG said, Roboteers 2481 did just that at Wisconsin. OPR of 48.7, tops at the event. They lost a very close Finals round, mostly because they tipped in F3 and spent pretty much the whole match on their back. I expect them to win at Crossroads next weekend assuming they will find a decent power shooter to pair with (their shooter is fine on their own, too).
  #74   Spotlight this post!
Unread 27-03-2013, 07:01
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
So.... 1114?
1114 is in a category by themselves.
  #75   Spotlight this post!
Unread 27-03-2013, 08:27
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
Honestly, all of the above is true, but to be frank I haven't seen many pure 50 point dumpers that actually get 50 points a match. A lot of teams assumed the "dump" part would be easy, but then just ended up being only 30 point climbers, which is a LOT less valuable.
The 50 point dump would still be a strong contender at regionals and very possibly on the right winning alliance, if it consistently existed and the right picks fell to the right alliance captain.
in the finals at boston this year at the end of the match there were very few white disks left. I think at champs there will be some strong 2 robot teams that can on there own shoot all of their white disks. Leaving the third robot to climb and dump. If on a deeper field a dumper sleeps to be the last robot picked that alliance will be hard to stop.
