Go to Post Holy cow! Five years in FIRST and it only gets better! Skyway has supplied wheels to FIRST for ten years. Ten years ago Dean called Ken for wheels. Ken said yes. Man, we love helping you guys and gals get good wheels. ;) Bart at Skywaywheels.com - SkywayWheels [more]
Unread 27-03-2013, 22:02
BPtigers BPtigers is offline
FRC #4663 (i8sumpi)
BPtigers is an unknown quantity at this point
Error when building code
I get error when I build code to deploy.
>AB_Destination.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW: File permission error. You do not have the correct permissions for the file.
Every single time any ideas, I need to know ASAP
Thanks
Ben
Unread 27-03-2013, 22:11
Re: Error when building code
I believe you need to look at the destination of the build location. You may need to create folders up to the destination or you may need to change permissions on the destination directory.
Greg McKaskle
Unread 27-03-2013, 22:14
Did you recently copy your code from one computer to another, or did you rename the project directory? Check the local destination directory. Make sure it points to a directory that actually exists.
In the project explorer window, right-click on FRC Robot Boot-up Deployment and choose Properties.
Click on the Information Category in the left-hand pane.
Verify the Local destination directory. If the user name and/or project directory is wrong, correct it.
Unread 27-03-2013, 23:01
FRC #4663 (i8sumpi)
Yeah I copied the code to another computer, I checked the local directory thing thanks everyone my team starts tomorrow.
Ben
